280z Front bumper conversion. Kaminari or MSA Type 3?
My 78 280z has the stock bumper that I'd like to convert to a sleeker air dam.
The problem I'm running into, however, is that the air dam I want (the Kaminari) only fits the 240/260. I think modifying it, and switching the parking lights will be a pain in the arse. So I'm instead considering the MSA type 3 with the grill, but it looks hit or miss in the photos (some looks angular and aggressive, others look rounded and 90s-sequences.)
Do anyone have either mounted they can share pics of? Or does recommend one of the other for a 280z? Also open to other solutions and air dam types. Just not a fan of those big arse bumpers!
I purchased this one through MSA, I did not want the hassle of changing the location of the blinkers.  This is a fiberglass model, the thing I don't link is that it is not flat up front, I say it looks like a buck tooth..LOL.   Otherwise, install was straight forward and I've had it a year without incident.  I did have to do a lot of prep work for a good finish though but believe that's the case with most of the fiberglass parts.  I also installed the fiberglass 240 style bumpers.
Thanks for responding! Just to be clear, you've had the type 3 with grill for a year? And installed the 240 style bumper? One of the reasons I'm considering the type 3 is because it has a built in bumper look with it.
I will check my receipt from MSA when I get back in a couple days. It's just an air dam, no aftermarket grill, using the one that was on the car slightly modified. It has no built in bumper look.
Not sure what you think will be different in posts here than by just going here: https://www.google.com/search?q=MSA+type+3+280z&safe=off&source=lnms&tbm=isch
Everyone's free to have their own opinions, but the MSA Type 3 is probably the worst looking of the "regular" options.
I did the Xenon air dam on my 260Z along with stainless steel bumpers. There is a version of the Xenon air dam for the 280Z that doesn't have the lower turn signals.
Looks great. Thanks!
3 hours ago, wheee! said:
@Eurodat for the bumper conversion parts. His system is artwork.
You can read through my thread. Might give yoh some pointers.
If you need anything, just send a pm.
Impo done properly, it really looks good.
  • Who's Online   2 Members, 0 Anonymous, 1,489 Guests (See full list)
