Missing a connector in the fuse box.
Vehicle 1974 260z 2-seater
The attached photograph shows the backs of my fuse box on the right and one I purchased on the left. The fuses are numbered top to bottom 1-7 on the right and 8-14 on the left of each box when viewed from the rear. The outer contact on my fuse No. 4 is missing. Someone spliced a purple box marked 12V10A 410 (upper right side of photo) branching off of the Green/White wire from fuse No. 3. A blue wire then extends from the purple box.
I’m assuming the blue wire used to go to No. 4 based on the wiring of the box I recently purchased. All would be fine except fuse No. 3 keeps blowing.
I’d like to reinstall the missing AGW fuse clip and run the blue wire back to its own fuse.
At last, the question: Where can I purchase a replacement AGW fuse clip?
A side question: What is this purple box and why was it installed?
https://www.classiczcars.com/forums/topic/58327-fuse-box-missing-a-connector/
I spoke with someone who came up with the same answer, a 10 amp breaker.
I'd like to replace the missing contact to split up the power between fuses Nos. 3 & 4.
Does anyone have a spare clip they are willing to part with?
I guess another option would be to install an in-line fuse to replace the missing fuse location.
Edited by Jeff Berk
update
