Well that's really a bummer. Not to mention the effort and more money you're going to put into a tranny that you though was ready to go.
Don't do it now though... Spend your time getting ready for the storm.
ok so after thinking on it some more, I am leaning toward just sending it out to be done. I have contacted a couple places, mulling over if I want to learn how to do something and buy a bunch of tools OR just pay the man. I am in this to have a fun hobby, my last attempts were somewhat less than fun, but I may still give it ago. will mull it over the next week, hopefully surviving Irma. I am getting pretty good at the swap process, think I got it down to about 6 hrs start to finish. Would be faster still if I had a lift. I think at the minimum I am going to buy another high lift floor jack. I have one that is only 2 tons but can lift 29". The 2 tons is fine for the light Z. My routine now is to place the jacks on the diff and cross member then jack some on one end, put the stands in place , then the other end. Takes about 2 rounds of jacking and positioning to get it to the final height. If I go for the full rebuild I will at least need some bearing pullers and various spacers to pull the main shaft back in .
