lking240 Posted September 14, 2017 Share #1 Posted September 14, 2017 Hi all, I've searched various z forums and haven't run across anyone with experience with this wheel issue so here goes- if anyone has Enkei 92s 14inch with 15mm offset can you let me know if you needed to use any spacers to prevent the wheel from rubbing on the strut or anything else on a 72 240z? Thanks, Lisle Link to comment https://www.classiczcars.com/topic/58536-enkei-92-with-15mm-offset-fit-question-spacers-needed/ Share on other sites More sharing options...
gundee Posted September 15, 2017 Share #2 Posted September 15, 2017 I can tell you I had 14 x 6-1/2" wheels with 13mm offset for a long time and had no issues at all. I think I was running 205/60-14 tires. Link to comment https://www.classiczcars.com/topic/58536-enkei-92-with-15mm-offset-fit-question-spacers-needed/#findComment-530348 Share on other sites More sharing options...
lking240 Posted September 15, 2017 Author Share #3 Posted September 15, 2017 Thanks Link to comment https://www.classiczcars.com/topic/58536-enkei-92-with-15mm-offset-fit-question-spacers-needed/#findComment-530355 Share on other sites More sharing options...
