wheee! Posted February 16, 2018 Share #61 Posted February 16, 2018 Nice work as usual Jeff. I’m particularly impressed with the panel tensioning on the hatch. I have yet to tackle my hatch and I’m sure it will need similar love. I haven’t seen your Porsche build but do you lay down a sealing coat after all body work is complete? Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-542491 Share on other sites More sharing options...
Patcon Posted February 16, 2018 Share #62 Posted February 16, 2018 Jeff, I had a couple of questions on your paint booth. If I heard right, you are pressurizing your booth? I also believe you had another video for building the booth for the Porsche, maybe a link. Are you blowing both fans in or just one in and one out? Did you have very much trash in the Porsche paint? My booth right now is setup with negative pressure and I get a fair amount of trash in my paint. One reason is a soft sided booth tends to shed trash when they billow. So I like the idea of positive pressure in the booth. just trying to get some feedback so I can figure out how to redesign my booth. Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-542498 Share on other sites More sharing options...
Home Built by Jeff Posted February 16, 2018 Author Share #63 Posted February 16, 2018 1 hour ago, wheee! said: Nice work as usual Jeff. I’m particularly impressed with the panel tensioning on the hatch. I have yet to tackle my hatch and I’m sure it will need similar love. I haven’t seen your Porsche build but do you lay down a sealing coat after all body work is complete? No, I didn't lay down an epoxy on the 911 before paint. It was always stressed, that bog has to go onto bare metal. It is only a more recent change with the new paint technology, that you can put bog over the new epoxy primers. Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-542508 Share on other sites More sharing options...
Home Built by Jeff Posted February 16, 2018 Author Share #64 Posted February 16, 2018 30 minutes ago, Patcon said: Jeff, I had a couple of questions on your paint booth. If I heard right, you are pressurizing your booth? I also believe you had another video for building the booth for the Porsche, maybe a link. Are you blowing both fans in or just one in and one out? Did you have very much trash in the Porsche paint? My booth right now is setup with negative pressure and I get a fair amount of trash in my paint. One reason is a soft sided booth tends to shed trash when they billow. So I like the idea of positive pressure in the booth. just trying to get some feedback so I can figure out how to redesign my booth. Watch both of my how to build a spray booth videos. In the first one I just had a negative pressure fan, like most professional booths. The issue is, that they are properly sealed, rigid units, so it works well. In my second video, I get another identical fan and have one pushing in through a filter and one sucking out. The fans work better at pushing than pulling, which makes the booth positive pressure. There are a heap of benefits to positive pressure in this situation. For starters, the sides push out which gives you heaps more space to work. The biggest benefit though, is that it is always pushing any dust out. As it is a tent, it is not completely sealed, and if it is negative, dust will get in where ever it can. My 911's paint is a little dry in a couple of spots, where my painting skills fell down, but there is basically no dust in it at all. It is better than half of the professional booths I have worked in. Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-542511 Share on other sites More sharing options...
wheee! Posted February 16, 2018 Share #65 Posted February 16, 2018 2 hours ago, Home Built by Jeff said: No, I didn't lay down an epoxy on the 911 before paint. It was always stressed, that bog has to go onto bare metal. It is only a more recent change with the new paint technology, that you can put bog over the new epoxy primers. I too have an epoxy primer base, followed by the body filler, then a sealing coat of epoxy on top of that. The body shop recommended this as a way to prevent any off-gassing of the fillers through the top coat. I also am using the water based paints for top coat and so far I like them a lot! Very consistent and easy to work with. 1 Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-542519 Share on other sites More sharing options...
Patcon Posted February 16, 2018 Share #66 Posted February 16, 2018 Thanks Jeff 1 Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-542523 Share on other sites More sharing options...
Home Built by Jeff Posted February 23, 2018 Author Share #67 Posted February 23, 2018 (edited) This week I get to see how my wing came out, and it was not as great as I hoped. Edited February 23, 2018 by Home Built by Jeff 1 Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-543130 Share on other sites More sharing options...
esmit208 Posted February 23, 2018 Share #68 Posted February 23, 2018 Like most others I too didn't realize you were here. Very nice work and lots of room to get it done BTW. But I am curious, when do you find time to go to an actual JOB or is it not a necessity where you are? You have a bunch of cool stuff going on and seemingly plenty of time on yourr hands! We should all be so fortunate. Maybe someday down the road I will be able to put my hands on a nice TARGA. I always liked that one. Keep up the good work and DEFINITELY KEEP MOMMA AROUND! She is what got my attention initially but like always cars prevail! Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-543134 Share on other sites More sharing options...
Home Built by Jeff Posted February 23, 2018 Author Share #69 Posted February 23, 2018 7 minutes ago, esmit208 said: Like most others I too didn't realize you were here. Very nice work and lots of room to get it done BTW. But I am curious, when do you find time to go to an actual JOB or is it not a necessity where you are? You have a bunch of cool stuff going on and seemingly plenty of time on yourr hands! We should all be so fortunate. Maybe someday down the road I will be able to put my hands on a nice TARGA. I always liked that one. Keep up the good work and DEFINITELY KEEP MOMMA AROUND! She is what got my attention initially but like always cars prevail! Haha, I am a Firefighter, so I work 24hour shifts on strange days. That gives me a bunch of days at home when everyone else is at work, to work on my cars Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-543135 Share on other sites More sharing options...
Patcon Posted February 24, 2018 Share #70 Posted February 24, 2018 1 hour ago, Home Built by Jeff said: Haha, I am a Firefighter, so I work 24hour shifts on strange days. That gives me a bunch of days at home when everyone else is at work, to work on my cars I thought you might be when I saw your pants with the reflective strips. By the way Jeff, love the new bug. I have a "one owner" 56 bug my dag bought new in Germany waiting for it's turn. Next in line after the Z currently on the rotisserie... 1 Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-543146 Share on other sites More sharing options...
charliekwin Posted February 24, 2018 Share #71 Posted February 24, 2018 Jeff, somehow I missed this thread, but YouTube's algorithm picked up the slack and your videos popped up in my feed a few days ago, and I've been following along since. Great work and great videos. Oh, I spent nine years as a firefighter as well! 1 Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-543167 Share on other sites More sharing options...
Home Built by Jeff Posted March 2, 2018 Author Share #72 Posted March 2, 2018 This week I have finally gotten to primer the inside of all the panels, and I get on to tackle the fuel flap. 1 Link to comment https://www.classiczcars.com/topic/58542-home-built-z-full-video-build/?page=6#findComment-543619 Share on other sites More sharing options...
