Jeff, I might have missed it, but are you clear coating everything or is that a single stage paint? Looks cleared in the final shots but I didn’t see you spray clear.
Also, how did you paint the hinges? Closed or open position? Did you paint all the surface area (open or close the hinge)? Same for the bonnet hinges...
Thanks for these videos, it will help immensely with my paint work later next spring!
There are 3 layers of base colour, then 3 layers of the translucent top coat, then 3 layers of clear. As for the hinges I painted them all open, and I will go back with the airbrush if there are still bits the show without colour.
  • Who's Online   1 Member, 0 Anonymous, 1,544 Guests (See full list)
