Trying to decide on what to install next.  Put the rear end back in?  Can I put the driveline in after the rear end is in?  I assume there is enough play on the yoke to accomplish that?  Should I put anti seize on the fill and drain plugs on the diff?
1 hour ago, Diseazd said:
Wow....Very impressive....I love the speed of the restoration....just enough Resto mod......just enough pure stock.....this car will look great and be a blast to drive!
Thanks it will need to slow down soon, I am getting my 77 bronco (full frame off restomod) back from paint in the next week or 2.  I will need to focus on that for a bit.  It's like 90% done or more.
9 hours ago, duffymahoney said:
Ok slightly torn between 2 very similar tire size.  205/55 R15 and 205/50 R15
Any input?  Going Dunlop DIREZZA
I am running 225-50-15's, Kuhmo's.  About $60 a tire, very happy with them.
