duffymahoney Posted October 2, 2017 Author Share #73 Posted October 2, 2017 Interesting. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-531495 Share on other sites More sharing options...
duffymahoney Posted October 4, 2017 Author Share #74 Posted October 4, 2017 Got the oil changed in the transmission, wow did it smell nasty. I hope the transmission is good. I also will be replacing all hoses, got the brake master done, used some copper wire to create the stock bends. Also removing heater hoses with the AC unit was a giant pain! Booster is back from being rebuilt. Only issue is it came back with a paint run in it. But it's on the bottom, so I won't worry about it. My 15/16th master cylinder won't work, the stupid bleeders are on the wrong side and hit the air cleaner:( I will have to find another or go wilwood. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-531631 Share on other sites More sharing options...
Patcon Posted October 5, 2017 Share #75 Posted October 5, 2017 I don't understand why the bleeders are a problem? Is it because you can't the air cleaner cover off and on with them there? Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-531673 Share on other sites More sharing options...
duffymahoney Posted October 5, 2017 Author Share #76 Posted October 5, 2017 3 hours ago, Patcon said: I don't understand why the bleeders are a problem? Is it because you can't the air cleaner cover off and on with them there? Exactly. Air cleaner cover can’t go on and off, hits the bleeders. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-531697 Share on other sites More sharing options...
duffymahoney Posted October 5, 2017 Author Share #77 Posted October 5, 2017 Changing all belts and hoses. So far so good. Also going with a plastic fan instead of my stock metal. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-531698 Share on other sites More sharing options...
duffymahoney Posted October 5, 2017 Author Share #78 Posted October 5, 2017 Found all the belts and got them installed along with my radiator and hoses! She might someday run again. Also found out my AC idler pulley was seized, but luckily someone on a site had found a napa part #38038 that matches perfect, either then pressing a bearing out, plus the pulley was cast iron and heavy and rusted. 1 Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-531735 Share on other sites More sharing options...
duffymahoney Posted October 6, 2017 Author Share #79 Posted October 6, 2017 Hopefully the gas tank will go back in next week after coating, started to replace hoses today. Going with normal rubber gas lines, not the braided, I am not going to do braided on anything. I strangely don't like the way it looks. Sorry guys. But I am very happy to find no rust behind these panels! Just lots of dust. Clamps still look brand new, a few of the grommets are ruined and dried, but I should be able to get the areas cleaned and done fairly quickly. Also looks to have had the rear taillights switched out at some point? Or a new wiring harness? So strange. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-531815 Share on other sites More sharing options...
duffymahoney Posted October 10, 2017 Author Share #80 Posted October 10, 2017 Got my dunlop 205/55-15, they don't look very big! Also if anyone has ever had to change the heater core hoses, knows my pain, that sucked. But almost all rubber hoses are replaced as of now. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-532051 Share on other sites More sharing options...
grannyknot Posted October 10, 2017 Share #81 Posted October 10, 2017 It's almost easier to pull the whole dash than it is to climb in upside down with your face crammed into the passenger foot well, miserable job. Did you also change the heater valve while you were in there? Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-532052 Share on other sites More sharing options...
duffymahoney Posted October 10, 2017 Author Share #82 Posted October 10, 2017 11 minutes ago, grannyknot said: It's almost easier to pull the whole dash than it is to climb in upside down with your face crammed into the passenger foot well, miserable job. Did you also change the heater valve while you were in there? I didn’t change the valve. It looks brand new and holds pressure. Fingers crossed! Also tested the heater core. But it could still be bad. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-532053 Share on other sites More sharing options...
w3wilkes Posted October 10, 2017 Share #83 Posted October 10, 2017 (edited) Yes, I just replaced my heater core hoses a couple of weeks ago. More fun than laughing right out loud! Found in another thread that the key is to unscrew the valve from the side of the heater core, undo the little hose from the valve to the core and then completely remove the valve from the hose that goes through the firewall. This gets you "almost" decent access to the hose closest to the firewall. Then went in reverse. Still a pain in the butt. I also replaced that little reducer hose by the block heater hose and ordered a backup, I figure that little piece of hose with the 2 different size ends will be discontinued like some of the fuel tank vent hoses. Edited October 10, 2017 by w3wilkes Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-532056 Share on other sites More sharing options...
duffymahoney Posted October 10, 2017 Author Share #84 Posted October 10, 2017 I have ac. So it was even worse. 1 Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=7#findComment-532057 Share on other sites More sharing options...
