2 minutes ago, duffymahoney said:
I have stock style wire ones. I am waiting on a L fuel fitting from Japan. Then I swill swap them all out.
Can you elaborate on the "L" fuel fitting? Why are you using it? Do you have a pic of what it looks like you can post? And where are you getting it from?
I am going to build a similar set up and would love to know the details. Thanks!
16 minutes ago, duffymahoney said:
You can see one L and 2 Ts on my carbs. One of the T’s has a called end. 1 L i have now is a left. I need a right facing one. They are a little harder to find.
I guess I have the same issue then. Any leads on finding a right facing "L"? Thanks
11 hours ago, duffymahoney said:
It’s designed to go one way.  It holds the fuel filter in and has a inside flange.
ok, that makes sense
I did a little looking. Looks like it might be a hard find. You might could rework one. Under the plating the tube is soldered or brazed in. Heat it and reverse it and have it replated. Not a very cheap way to do it, but it should get you to where you want to be
Finally found some series 1 wheel chocks.  I sent off for around 30 yellow powder samples.  I decided on 02 VETTE YELLOW by Prismatic powders.  It was close, just slightly brighter, I think when new this would have been almost identical.  First picture was taken indoors under terrible lighting.
This finishes off my series 1 tool kit.
  • 4 weeks later...
Ok, now onto my horns.  I always hated how they look.  Poor repray covering them.
Interesting that the front of the horns looked to have been the dark green zinc. Then sometimes from the factory with some over spray.  Same zinc as the seat sliders.  ZedSaver does gold zinc.  I am a little torn on what to do.  Also how to take this fully apart to zinc?  You can see in the blue z picture the green really showing through.
I finally got the correct fuel fitting from japan to finish my old school looking fuel rail. I love how it turned out! I had to have it re - zinc’d since the Mikuni and my plater color didn’t match.
Edited by duffymahoney
  • Like 3
  • Who's Online   2 Members, 0 Anonymous, 1,227 Guests (See full list)
