34 minutes ago, Diseazd said:
Really cool project. Does the ports on your intake manifold match up with the intake ports on the head? Seems to me when I was at Eiji’s shop, the Jenveys needed work on my head to match the ports on the intake.
Jenvy’s should match right up to my SK intake.
2 minutes ago, madkaw said:
The wheel is for a crank sensor ,  Im not sure how it works for a cam sensor .
I get a little confused on all the signals and such.  But most crank sensors are 36-1 which tells the ecu it a lot of info but not enough to know if it's intake or exhaust. The 60-2 tells the ecu exactly what stroke its on.  So that is all it needs.  But again, I am a giant newbie on all of this.  So?
  • Who's Online   1 Member, 0 Anonymous, 911 Guests (See full list)
