I’m not going to rattle can my new stroker block.  So I need a color code off something.
The alternator bracket seemed like the best choice for still have original paint and be something I can easily take off. I found another that was plated to replace it. This is the last grimy thing on my original motor.
 I will have a ppg shop scan it next week. It’s darker blue then I would have guessed.
Edited by duffymahoney
I got pretty far on the intake. I figured out my basic plan. I also tig welded the old holes and drilled and tapped new ones. So they are centered better.
I tapped all existing holes for npt plugs. I also drilled each runner to 9mm. I bought a bspt 1/4 for the stock pcv fitting. Also a 5/8 hose Barb by 3/8 npt brass for the iac.
I also had my stacks turned down to fit some cheap filters. Brass or no brass?
My decision on iac location.  I can use the stock 12v + from the coil and also the coil negative wiring for the iac connected to my haltech. So wiring will stay the same.
Why don’t you live near me?? We have so much in common...
  • Who's Online   2 Members, 0 Anonymous, 1,460 Guests (See full list)
