Well it runs, but terrible.  I have a massive vac leak, either from my balance bar not sealing or maybe a throttle body wasn't bolted down correctly.  Even with throttle plates in the full closed position it runs happily at 900 rpms. So it's getting a ton of air from somewhere.
On 3/30/2020 at 7:21 PM, duffymahoney said:
Well the 80s bmw iac is awesome, smaller and nice looking. Let’s no air or minimal amount by when physically closed Now to find out what pin is positive.
Can you share a part # or specific BMW make/model/year?
  • 4 weeks later...
1 hour ago, Patcon said:
So what is in the Rebello 3.2 kit?
What do you have to provide?
What head will you pair with it?
It requires you have a diesel crank to offset grind and a block that will go to at least 89mm - I believe.
Thats the way mine is anyway . You can pair is with any head with any compression - that’s a matter of preference . I think he can make a 3.0 out of any L28 block and crank . To get the extra .2 required a longer stroke .
I sent my diesel crankshaft and a N42 block and $$$ and I got back all the ingredients to put one together . Rebello preps  the block and crank - custom pistons and all bearings .
  • Who's Online   1 Member, 0 Anonymous, 767 Guests (See full list)
