Rainy Sunday z project! Finally got my cable mount installed for my new cable driven ITB setup. This is a lokar cable to a stock 240z pedal with the ball end removed. Then I made a tiny bushing. Everything is snug and works as it should.
  • Agree 1
  • 3 months later...
Well I ended up selling my SKs.  I am going EFI hardware pro throttles and a vintage FET V1 intake.  The FET has about a perfect injector angle and should spray fuel directly down the middle of the runners.
The only real issue is they have huge ports at the head, so I will be welding them up and matching to my head.
I got the idea for the angle here.  This is a Fet v2 or v3.  The issue with those intakes is the middle carb/ throttle is higher. So you can't run a solid fuel rail.  Also this version of the FET has 30mm runners at the head.  So lots of porting is needed.
Also I got my taper bore pro EFI hardware 45mm throttle bodies! They are cnc cut and very pretty, the have the most shallow injector angle I could find, and I love the bearings, 8mm shafts and butterfly angle.  Sadly they were damaged in shipping, so back to waiting.
Since my throttles are taper bore.  There isn't a velocity stack that looks classic and is the correct size, so I had these drawn up and cnc cut.  Sadly I screwed up a measurement, so they have to get cut again.  These are 65mm length stacks, which I think make them look better with the shorter throttle bodies.  Thoughts?
  • Like 3
  • Who's Online   1 Member, 0 Anonymous, 1,461 Guests (See full list)
