Version 2 of my 10mm throttle arms are done. I recessed the hardware a little more and added a 5mm allen for safety. Plus designed up a return spring setup to match! I think I’m happy with this asthetics.
  • Like 3
  • 3 weeks later...
Well I got my cnc intake! Honestly surface finish isn’t what I was hoping for. But will be nice with some effort. I think it’s almost too much bling. I might go satin glass bead on the intake. It has pretty heavy machine marks
Balance bar bolted on exactly as I planned, with 6mm banjos. The injector angle looks spot on as well.
Pretty happy with it overall. Next rods need to be shortened and I need to figure out a progressive throttle location on the overhead bar and a cable mount location. Then moving the ecu temp sensor.
  • Like 3
  • Wow 1
