duffymahoney Posted August 11, 2023 Author Share #961 Posted August 11, 2023 I am trying to get better spring engagement on my R35 Coil stalks. Here is v5. I hope it works! 1 Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-655819 Share on other sites More sharing options...
duffymahoney Posted August 11, 2023 Author Share #962 Posted August 11, 2023 I have proper spring engagement! Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-655825 Share on other sites More sharing options...
duffymahoney Posted August 17, 2023 Author Share #963 Posted August 17, 2023 Finally nailed down a perfect length, bend with proper spring tension to the spark plug! Now off to Thailand to be made. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-656031 Share on other sites More sharing options...
Patcon Posted August 17, 2023 Share #964 Posted August 17, 2023 Thailand? How many are you making? Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-656034 Share on other sites More sharing options...
duffymahoney Posted August 17, 2023 Author Share #965 Posted August 17, 2023 (edited) 47 minutes ago, Patcon said: Thailand? How many are you making? I will probably sell like 20-25 kits. A guy in thailand makes a bunch of stalks for the r35 coils. He will be making these, same material as stock. Edited August 17, 2023 by duffymahoney 2 Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-656038 Share on other sites More sharing options...
Patcon Posted August 17, 2023 Share #966 Posted August 17, 2023 1 hour ago, duffymahoney said: I will probably sell like 20-25 kits. A guy in thailand makes a bunch of stalks for the r35 coils. He will be making these, same material as stock. Are you going to post an ad here? Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-656044 Share on other sites More sharing options...
Blitzed Posted August 18, 2023 Share #967 Posted August 18, 2023 Kit includes the rail? I'm in. Running single coil sequential now but the EFI distributor allows conversion to COP or batch. Let me know when the kits are available. Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-656049 Share on other sites More sharing options...
duffymahoney Posted August 18, 2023 Author Share #968 Posted August 18, 2023 I plan to make and sell a full kit on my webpage, I will post links on here when it's all finished. 1 Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-656063 Share on other sites More sharing options...
duffymahoney Posted September 7, 2023 Author Share #969 Posted September 7, 2023 I finally got my fixed cnc stacks in! They look amazing 1 Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-656821 Share on other sites More sharing options...
duffymahoney Posted October 23, 2023 Author Share #970 Posted October 23, 2023 I decided to make my own intake, this is modern version of my FET. I love the angle for the injector and also getting the throttles away from the heat of the header Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-658502 Share on other sites More sharing options...
Zed Head Posted October 23, 2023 Share #971 Posted October 23, 2023 No injector ports are shown. Is that bar meant to be a fuel rail? The nipples are confusing, with one in the middle and one on the end. Why would you want the injectors so far from the head? Is this just a thought experiment or are you really planning to build something? Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-658503 Share on other sites More sharing options...
duffymahoney Posted October 23, 2023 Author Share #972 Posted October 23, 2023 1 hour ago, Zed Head said: No injector ports are shown. Is that bar meant to be a fuel rail? The nipples are confusing, with one in the middle and one on the end. Why would you want the injectors so far from the head? Is this just a thought experiment or are you really planning to build something? This will use my EFI throttles, so injectors at the throttles, the angle of the intake puts the injector spraying right down the middle of the runner! Bar on the bottom is for map signal, it uses 6mm banjos. Middle port will be for the ECU, end will be for the FPR. I will be making at least one. 1 Link to comment https://www.classiczcars.com/topic/58568-duffys-171-series-1-240z-build/?page=81#findComment-658510 Share on other sites More sharing options...
