Big difference between gas smell and EXHAUST smell . It seems you are referring to exhaust . Many ways for it to get in the cabin if car is not properly sealed . Start searching exhaust fumes on this site and others.
Biggest culprits
tail light seals
hatch seals
inner hatch panel seal
8 hours ago, zdude1967 said:
Does your Z have the carbon canister system hooked up
Yes I do but again, I think you are smelling exhaust instead of fuel. If you're running a little rich, it's probably mixed in your exhaust and you might smell that as well. You can get a smoke machine and look for cabin leaks and I bet you'll find them in the areas noted above.
  • Who's Online   0 Members, 0 Anonymous, 1,410 Guests (See full list)
