12 hours ago, dutchzcarguy said:
These are now for NCV.. ?  (Meaning NO crankcase Ventilation) :ph34r:
Not sure what you are saying . the PCV connection is still there under the left linkage arm where it always was. These have both the PCV and brake vac connections.
https://www.classiczcars.com/topic/58637-balance-tube/#findComment-531598
I am curious on your polishing technique.  Are you using Clay bars, what brand?  Sanding? 80, 180, 400, 800, polish?
https://www.classiczcars.com/topic/58637-balance-tube/#findComment-531627
Now I see, I couldn't remember where the PVC opening was, here is a couple of balance tubes I did a few years ago, after all the grinding and sanding I couldn't bear the thought of polishing them too, kudos to you for going all the way.
https://www.classiczcars.com/topic/58637-balance-tube/#findComment-531669
I start with a large body file, than finer files until the shape is correct. Than on to sandpaper going from 80 down to 600. After than a couple of 3M super fine and micro fine sanding pads. Than on to the buffing wheel starting with the black and finishing with the red polishing compound. A clean with Mothers Alum polish to finish it off. It is quite a bit of work to get one done. The most aggravation comes from the files loading up with alum and causing deeper scratches than the file.
https://www.classiczcars.com/topic/58637-balance-tube/#findComment-531734
I heard that running the file over a bar of soap now and then keeps the file from clogging with aluminum.  Well, actually I heard this technique for grinding disks, but the theory should be the same.  Tube looks awesome...me, too lazy to attempt such a thing.  But, I am smack dab in the middle of polishing a vintage Airstream trailer.  The effort is messy, and tiring for sure...after a few hours, I turn black.
Edited by David F
https://www.classiczcars.com/topic/58637-balance-tube/#findComment-531736
  • Who's Online   1 Member, 0 Anonymous, 1,599 Guests (See full list)
