Although they were stuck to the metal, I didn't really get the feeling that the paper gaskets in my horns had any kind of glue or sealant used.  I agree with Grannyknot that you don't want water getting inside.  I debated about using sealant.  I even thought about using thin-sheet neoprene foam rather than paper when I cut new gaskets. However, I was worried that a thicker or softer material might mute the horn, so I just used thin gasket paper (dry).  After all was said and done, I ended up with the characteristic Z horn sound that I wanted, but I don't think it's loud enough to get the job done in modern traffic so I'm going to back them up with a pair of FIAMM 'Freeway Blasters'.
https://www.classiczcars.com/topic/58669-horn-repair/#findComment-531789
  • Who's Online   0 Members, 0 Anonymous, 1,544 Guests (See full list)
