1 hour ago, esmit208 said:
SHOCKS MOUNTS........Explain please.
AKA "soft mount": Rubber O ring insulators between the carb and manifold. The carbs are then secured with either bolts passing through rubber grommets or thackeray washers.
Thanx 468 I need all the help I can get....?.WOW am I excited!
