After months of patiently waiting on logistics, I was able to trade my old MSA Type 1 air dam for 5 speed from a 280Z.  I came out of a running car, and the input shaft seems to spin freely without much play. It is dirty and I fully intend to get it rebuilt prior to installation.  I just wanted to check.  Having put a new clutch and pressure plate and throwout bearing and clutch collar in my last car, can I reuse those?  You match all the clutch hardware with the clutch if I recall. It has been a while since I did the research on this.  I was planning on using my 240Z 4 speed collar fork and everything else... I will dig around in the 5 speed swap section to see if this is right.  But I am psyched. I will finally be able to drive with the flow of traffic on the freeway without turning 4500 rpm.
https://www.classiczcars.com/topic/58949-280z-5-speed-has-landed/
  • Who's Online   0 Members, 0 Anonymous, 1,570 Guests (See full list)
