2 hours ago, rturbo 930 said:
I don't really get the confusion with the series one designation. It's a made up term to identify cars with certain features, built in a certain time frame.
The main problem is that people use the term inaccurately, and apply it to details and features which don't fall neatly into such pigeonholing.
As can be seen on this thread...
12 hours ago, rturbo 930 said:
I don't really get the confusion with the series one designation. It's a made up term to identify cars with certain features, built in a certain time frame. IMO the set in stone features of the series one cars are the hatch vents, '240z' badges on the C pillar, and lack of integrated storage/tool bins, and maybe a few other features like the solid spoke steering wheel. There were many changes within the range that series one cars were built, I don't think that negates the function or usefulness of the term.
I agree with rturbo.  I have a 5/71 and there are a lot of similarities.  Grease reservoir in the steering rack, type b transmission tunnel, series 1 console, choke, radio, e31 head.  I would pay attention to the radio, console & choke, b-pillar emblems, rear deck vents, rear deck window, tool boxes, seat hardware, steering wheel, and the elusive hand throttle.
I thought only a select few of the early models had the 2400 valve cover.
Surely the fact there's no clear cut off or a factory change, just shows it will not work as a 'series' descriptor.
I'm far from an expert, from what I've seen, read, it was all a gradual change with little bits changed during the production run.  Thats why early/late works as a descriptor.
Its seems to be a constant evolution.
Early/late is too vague. Without context, it could mean anything. To simply say you have an 'early' Z could mean anything. It could mean any 240z, any series one 240z, any 1970 series one car built early in the year, or any series one car with a 1969 build date. In the context of 1969 build date cars, it could even mean only very early build date 1969 production cars. When you refer to a Z as a series one, most people who have been around here for a minute know exactly what you're talking about.
And I would argue that there is a clear cut off. For US cars, VINs under, I believe, about 20500, build dates up to 1/71 - although recently there was a late production series one car that had a 2/71 build date, but that is an anomaly, and I've never seen such a thing.
It works just fine as a 'series' descriptor, has for many years. I certainly wouldn't consider myself an authority on the matter, but I think my definition of a series one car is pretty accurate. It is not meant to apply to cars with an exact selection of parts. Also, I would only apply it to US models. I don't know the non-US Z market that well, so maybe it could apply to cars outside of the US market, but I am assuming that the term originated in the US, and is best applied to US market cars. Someone else can chime in if they feel differently.
There's been a 3/71 build car that's an early body and none vented quarters.
Your statement is a contradiction, there's no clear cut off, not a documented one, not one that in 40odd years people have managed to put a date/build number to. If so it would be easy and factory correct.
You can apply early to just about any world market based on the body?
Can you link me to this 3/71 dated series one car? This is the one I was referring to: https://bringatrailer.com/listing/1971-datsun-240z-17/
I said about 20500 because I don't recall the exact number. It's not like there's a few series one cars with VINs 21000 and up. They are ALL under a certain VIN. As for build dates, most VINs correlate with a certain build month, but every so often there is an outlier, I would assume due to some sort of issue or event at the factory. If I am not mistaken, VINs were applied to shells in order, and date stamps were done as they were completed (can someone confirm/expand on that?), so if one shell gets held up for some reason, it will end up with a later build date. I am stretching my memory here, but that is my understanding of VIN/build date mismatches based on what I've read over the last decade. And once again, I am referring to the US market cars.
I am not sure which part of my post you're referring to with your last sentence. I am only talking about US market cars.
I think you are trying to apply an overly specific definition to the term "series one." As previously stated, it is not meant to apply to an exact selection of parts and features. And to be honest, I'm not sure if it really needs to have an exact VIN or build date cut off to be of use, even though I still maintain that there IS a VIN cut off, and save for a few outliers (actually just one that I know of), a build date cut off. Also, due to the fact that these cars are old, and many have been lost, we probably won't ever know the exact VIN cut off. Based on the information on zhome.com, the last reported series one car has VIN 20438, and the first series two car has VIN 21001, with the change over month being January 1971.
On ‎22‎-‎11‎-‎2017 at 5:08 PM, w3wilkes said:
Rear brake wheel cylinders. Series I costs ~$200 US where Series II can be had for <$40 US. Guess which way I went on my Series I?
An interesting note on my Series I car. It came with the Series II map light bezel (the one with the hood).
I came across that problem last time when one of my cylinders was stuck from sitting in the winter and was leaking fluid. I managed to get only a new cup seal  ( few dollars ) and rebuild the unit, or else it would cost me that 200 + USD..
Thank god on these old cars everything is almost repairable, instead of the new cars where you just throw it away and buy a new one....$$$
Edited by bartsscooterservice
21 hours ago, Carl Beck said:
Why Series I and Series II
"Comfort and Convenience features - that were added or changed in the Series II"
I like this one new added Comfort and Convenience feature:
"A new pocket added to the sun visor affords increased convenience of the driver by providing storage for highway tickets."
:D too funny!
...and  Happy Thanksgiving!
Edited by 240Ziggy
  • Haha 2
