Okay I know I've posted this twice already but I really need help here. I am wanting to install a 4 bbl carb on my L28 powered '73 240Z. Which carb should I use? What about the linkage? The intake manifold? Any speacial instructions or modifications needed? Please help me!!
"Go into emptiness, strike voids, bypass his defences; hit him where he does not expect you" -Lao Tzu
https://www.classiczcars.com/topic/59-4-bbl-conversion/
Timberwolf, you're talking about a pretty standard conversion. There are kits available to do this.
You will need a special manifold that connects to your intake ports on the block.
I think someone has a 4-barrel conversion kit for sale in the FOR_SALE forum. Check that one out.
You will need to modify linkage and a few other items to make it work correctly.
But, when it's all connected I understand that it's a very reliable system.
That's all I know. Someone else will more than likely respond to you - just give it a few days.
[m]
Mike Gholson
1971 240z, Mikuni Carbs, Tokico 5-way Adjustable Struts, Ferarri Yellow, Stock Engine, 15x9 wheels w/50 series Falken tires, Currently being restored.
https://www.classiczcars.com/topic/59-4-bbl-conversion/#findComment-141
  • Who's Online   2 Members, 1 Anonymous, 1,433 Guests (See full list)
