Zed Head Posted January 12, 2018 Share #37 Posted January 12, 2018 2 hours ago, Patcon said: Right now were running the stock 510 carb which I believe is a 2 barrel vacuum secondary carb with an accelerator pump So one throttle plate and pumping the gas adds fuel... It also has a glass sided float bowl so you can instantly see if the carb has fuel So, a plain old carb like most of us raised on domestic cars learned on? Still, if the throttle plates open the engine should gain RPM. If there was a blockage in the fuel supply it would go lean and pop or stall. So timing does seem like a possibility. Retarded probably. I learned about retarded timing back when I was just learning the "time by ear" method. My ear was bad and timing got way off. Turned a 400 CI Pontiac engine in to a gutless wonder. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-539532 Share on other sites More sharing options...
Mark Maras Posted January 12, 2018 Share #38 Posted January 12, 2018 Does your 510 have a dual point distributor? Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-539533 Share on other sites More sharing options...
S30Driver Posted January 12, 2018 Share #39 Posted January 12, 2018 1 hour ago, Mark Maras said: Does your 510 have a dual point distributor? He has replaced the original distributor with an electronic ZX version Mark. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-539537 Share on other sites More sharing options...
Mark Maras Posted January 12, 2018 Share #40 Posted January 12, 2018 Thanks Jim. I was remembering the POS dizzy that I had in my 71 pick-up. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-539548 Share on other sites More sharing options...
Patcon Posted January 12, 2018 Author Share #41 Posted January 12, 2018 14 hours ago, Zed Head said: So, a plain old carb like most of us raised on domestic cars learned on? Still, if the throttle plates open the engine should gain RPM. If there was a blockage in the fuel supply it would go lean and pop or stall. So timing does seem like a possibility. Retarded probably. I learned about retarded timing back when I was just learning the "time by ear" method. My ear was bad and timing got way off. Turned a 400 CI Pontiac engine in to a gutless wonder. Yes, basically. It is possible it is a timing issue I probably need to check the vacuum advance and the centrifugal weights too. I don't know how we would watch timing in real time since it is such a sporadic issue Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-539559 Share on other sites More sharing options...
Patcon Posted April 25, 2018 Author Share #42 Posted April 25, 2018 Ok So some updates: We have gotten his car running. We pulled the old 2 barrel carb and replaced it with a set of SSS SU's that I rebuild and replated. The car runs much better and accelerates much better. But, since no good deed goes unpunished, we have a new problem! We are loosing water and over heating! The manifolds have a water passages from the head and connect to a pipe going around the front of the block. What is the best way for me to narrow down the leak? This is a major leak, like a gallon of water in 10 miles!!! There are no visible leaks that we have found. There is no carpet in the car right now, and we aren't seeing any water in the floor board. My thoughts are manifold passages leaking into the exhaust, a head leak or an external leak that we haven't spotted yet. Any ideas on the best way to go at this? I hate to pull the manifolds again if avoidable. You would think that amount of coolant into the exhaust would be noticeable. I would think it would steam like crazy and probably smell sweet to boot! Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-548047 Share on other sites More sharing options...
240260280 Posted April 25, 2018 Share #43 Posted April 25, 2018 A quick check would be to look at plugs so see if a chamber is drinking it... also check oil for chocolate milk. You can rig up a rad cap to take an air line (or buy one of those pressure test kits with one) and pressurize the system with 13psi. You may be able to hear the leak. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-548048 Share on other sites More sharing options...
NVZEE2 Posted April 25, 2018 Share #44 Posted April 25, 2018 A gallon just disappears? It sounds like that thing has become a water pump. Pull the plugs and crank it. Check the oil level. Hope that it’s burning because otherwise somewhere there’s a lot of unwanted juice. Did you check the manifolds, gasket, and head to make sure every hole aligned? As a side note, you’re going to be in very good company at the Mitty. Make a list of questions, take pictures, and get connected with the Datsun cognescenti ASAP. Knowledgeable, fun people there! Feast on the resources. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-548049 Share on other sites More sharing options...
Patcon Posted April 26, 2018 Author Share #45 Posted April 26, 2018 (edited) 1 hour ago, 240260280 said: A quick check would be to look at plugs so see if a chamber is drinking it... also check oil for chocolate milk. You can rig up a rad cap to take an air line (or buy one of those pressure test kits with one) and pressurize the system with 13psi. You may be able to hear the leak. I figured checking plugs and compression test would be next. I checked the oil, a little low but doesn't look milky 55 minutes ago, NVZEE said: A gallon just disappears? It sounds like that thing has become a water pump. Pull the plugs and crank it. Check the oil level. Hope that it’s burning because otherwise somewhere there’s a lot of unwanted juice. Did you check the manifolds, gasket, and head to make sure every hole aligned? As a side note, you’re going to be in very good company at the Mitty. Make a list of questions, take pictures, and get connected with the Datsun cognescenti ASAP. Knowledgeable, fun people there! Feast on the resources. I did not check the gasket overly close. I agree that's a lot of fluid going somewhere fast! Yup, I thought the Mitty would be a good place to make pictures and pick some people for ideas. It overheated on him the other day, because he forgot to refill it after installing the SU's. So we filled it and he ran it. He drove it 8 miles today to a friends house and it overheated. Was a gallon+ low on water. Filled it and drove it the 8 miles home. Almost 2 gallons low. We ran it for a while tonight with it rev'd and the water level didn't move. There seems to be a tiny bit of oil fill in the radiator... Edited April 26, 2018 by Patcon Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-548050 Share on other sites More sharing options...
gwri8 Posted April 26, 2018 Share #46 Posted April 26, 2018 I don't know how easy it is see the rear of your engine but are there any water trails on the block at the back of the head? Just throwing that out because that's where I had head gasket leak on my L28. Water would just disappear and the engine would start to get hot. I believe it would only leak with the engine at temp. Yours would probably be more obvious. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-548052 Share on other sites More sharing options...
240260280 Posted April 26, 2018 Share #47 Posted April 26, 2018 Sounds like head gasket. When cold, remove radiator cap and crank engine. It may blow like a geyser if the head gasket is only sealing when hot. If nothing at start then let the car come up to temp with rad cap off. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-548054 Share on other sites More sharing options...
SteveJ Posted April 26, 2018 Share #48 Posted April 26, 2018 Charles, I can introduce you to Rob Fuller who owns the Z Car Garage (http://www.zcargarage.com) in San Jose. He's here working on the BRE car among others. You might be able to pick his brain. He loves 5 & dimes, too. 1 Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=4#findComment-548059 Share on other sites More sharing options...
