Captain Obvious Posted December 16, 2018 Share #97 Posted December 16, 2018 Well with nothing similar to compare it to, 40mA (.040A) sounds completely reasonable to me. I've lost the details. Was there a tach installed before? Or are you putting one in where there previously was none? Point is... Do you have a second tach that you could compare against the one from the Goon? Or (being of the same inductive pickup concept and from same manufacturer and close to the same age....) Is there an early 240 tach that you could run the same test on for comparison? Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563865 Share on other sites More sharing options...
Patcon Posted December 16, 2018 Author Share #98 Posted December 16, 2018 5 minutes ago, Captain Obvious said: Well with nothing similar to compare it to, 40mA (.040A) sounds completely reasonable to me. I've lost the details. Was there a tach installed before? Or are you putting one in where there previously was none? Point is... Do you have a second tach that you could compare against the one from the Goon? Or (being of the same inductive pickup concept and from same manufacturer and close to the same age....) Is there an early 240 tach that you could run the same test on for comparison? Never had a tach I might could did up an early 240z tach and check it. We'll see what I get. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563868 Share on other sites More sharing options...
Captain Obvious Posted December 17, 2018 Share #99 Posted December 17, 2018 Well of course there's no guarantee that it would be the same, but I wouldn't be surprised if it was. Have you turned up a schematic of the tach circuitry? I've not looked for such a thing. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563904 Share on other sites More sharing options...
Patcon Posted December 17, 2018 Author Share #100 Posted December 17, 2018 48 minutes ago, Captain Obvious said: Well of course there's no guarantee that it would be the same, but I wouldn't be surprised if it was. Have you turned up a schematic of the tach circuitry? I've not looked for such a thing. I had two inductive loop Z tachs. They both measured .04 Amps too! So does that mean that the tach should work or could the circuitry still be bad? Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563912 Share on other sites More sharing options...
Captain Obvious Posted December 17, 2018 Share #101 Posted December 17, 2018 Oh, it could absolutely still be bad! Are you confident in one (or more) of the 240 tachs? Why don't you try hooking one of them up to the Goon just to see if you can get the needle to move. In theory, it should work regardless if it's connected to a 510 or a 240. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563916 Share on other sites More sharing options...
Patcon Posted December 17, 2018 Author Share #102 Posted December 17, 2018 9 hours ago, Captain Obvious said: Oh, it could absolutely still be bad! Are you confident in one (or more) of the 240 tachs? Why don't you try hooking one of them up to the Goon just to see if you can get the needle to move. In theory, it should work regardless if it's connected to a 510 or a 240. I thought about trying that Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563927 Share on other sites More sharing options...
Zup Posted December 17, 2018 Share #103 Posted December 17, 2018 21 hours ago, Patcon said: I might could did up an early 240z tach and check it. We'll see what I get. Is this some "high country" S.C. lingo??? "I'm a fixin" to add it to my linguistic skill set. 2 Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563928 Share on other sites More sharing options...
Patcon Posted December 17, 2018 Author Share #104 Posted December 17, 2018 2 hours ago, Zup said: Is this some "high country" S.C. lingo??? "I'm a fixin" to add it to my linguistic skill set. Add away! Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563930 Share on other sites More sharing options...
jfa.series1 Posted December 17, 2018 Share #105 Posted December 17, 2018 4 hours ago, Zup said: Is this some "high country" S.C. lingo??? "I'm a fixin" to add it to my linguistic skill set. Fixin' and y'all - two great words in our proud Texas vocabulary. Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563937 Share on other sites More sharing options...
siteunseen Posted December 17, 2018 Share #106 Posted December 17, 2018 Before my Grandaddy would give me a whipping he always gave me a last chance to do what he said with one word, "Y'ain't??? That word got a lot of toys picked up. 2 Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-563943 Share on other sites More sharing options...
Patcon Posted December 20, 2018 Author Share #107 Posted December 20, 2018 So here is the oil gutter. Still available new, at least for now. I thought I would post up some dimensions so they could be reproduced if they become NLA That is the part number showing in the first photo. It's pretty light gauge stuff. If I remember I will try to mic it this weekend. I believe the end is left open to aide in installation and evidently the lack of full closure doesn't affect the ability to catch sufficient oil Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-564139 Share on other sites More sharing options...
Patcon Posted January 1, 2019 Author Share #108 Posted January 1, 2019 I finally got Cody to do something today. I am waiting on just a few pieces for the tranny but in the meantime he needs to get the cases clean. This was after oven cleaner Thanks Cliff @siteunseen This was after blasting. We used the pressure pot because it's too big for the blasting cabinet. I need a bigger one... There was an interesting number on the top of the belllhousing He then shot a couple of coats of Diamond clear on it. Hopefully he will do the back half this weekend. In relation to that, does the shifter arm have a slot for the locking bolt to position it? We need to strip the rear case and I wouldn't think the shifter would have to be set in a certain position. I am assuming the rod is notched to allow the bolt to pass beside it and set the arm in a specific position. 1 Link to comment https://www.classiczcars.com/topic/59089-codys-goon/?page=9#findComment-565007 Share on other sites More sharing options...
