Almost all of those failures are in heavy duty truck tires. I worked as a diesel mechanic one summer and dealt with split rims a lot. They can be exceedingly dangerous!!! That ring will take your head clean off if it's not seated properly. They also run really high air pressures. Most over 100-120 #'s. That makes for a dangerous combination. That's why they have those cages to air them up in. To prevent these types of accidents. I wonder if the normal tires that blew up were filled with propane or were severely over inflated?
On a different note, it is amazing how much abuse the human body can take...
https://www.classiczcars.com/topic/59141-tire-dangers/#findComment-537146
5 hours ago, Mark Maras said:
 Anyone remember GMC split rims? They liked to separate under pressure if they weren't seated properly.
My dad's '67 GMC still has its split rims. Doubt I could find anyone who is willing to put new tires on. Easier to just get new rims and tires.
https://www.classiczcars.com/topic/59141-tire-dangers/#findComment-537188
  • Who's Online   1 Member, 0 Anonymous, 1,366 Guests (See full list)
