4 hours ago, jcb said:
esmit208, Thanks for the link. I have the tach out and am going to try the repair that is shown on  Z driver.com. If that will not do it I will try your link.  Thanks again, JCB
Sure, anytime. I'm actually looking at replacing as many of mine as possible. The look is cool but the technology will just get more and more dated and unuseable.
https://www.classiczcars.com/topic/59149-tachometer/#findComment-537318
I think it was a auto meter but don't think the brand would change much and all I did was use a old extra stock mounting cage I had from dead speedometer or tach the both the same and used a dremel tool cut out the back of said cage but leave the stock mounting holes and a fix the new tach in that cage then remount it as it did in the first place took me a couple hrs you just need to be a little crafty is all.
Sent from my SM-G530W using Classic Zcar Club mobile
https://www.classiczcars.com/topic/59149-tachometer/#findComment-537353
  • Who's Online   1 Member, 0 Anonymous, 1,101 Guests (See full list)
