Cannot get injector pulse - passes EFI bible tests!
I don't see the other ground wire for the EFI system.  It could be attached somewhere else but it came from the factory with a plastic connector, to a pigtail at the battery negative post.  Somebody has monkeyed with yours, that battery cable to the firewall is way overkill.
Edited by Zed Head
2 hours ago, S30Driver said:
Yes,  you are right Cliff.    The circled EFI ground in your picture.
3 hours ago, S30Driver said:
If it were mine,  i'd be cleaning & brightening up that important ground on the intake manifold.    In the pix,  looks like it has not been touched.
This one under the philips screw.
I cannot say how grateful I am for everyone's help. That was it. I cleaned that ground and it fired right up after getting all the air out of the fuel lines.
@Zed Head, I'm definitely going to do like you suggested and check everything now. I'd rather not have this again.
Thank you so much everybody, I hope you all have a very merry Christmas.
Just now, 240260280 said:
I think this was mentioned in post #6... but what do I know? ;)
You're right - it was. I misunderstood and thought you meant the other ground cable going onto the intake manifold, to the right side in my pictures. My bad.
I knew you had mentioned it but didn't read back far enough.  I caught S30's post and went from there.
That's what happens when you don't keep up. :facepalm:
Glad it came back around and was resolved.  Early Christmas present I'd say.
I love this forum!
