So I'm getting started of the restoration work of my 1978 280z.
The chassis repair and rust removal (replacement of floor pans and frame rails) and undercoating should be complete in a week or so.
I am wondering what my best option is for the interior (top side) of the new floor pans. I am not planning on painting for a few months and I do not want to risk the floors rusting again. Should I apply undercoat (POR-15) to the interior as well? Also, I have access to a lot of Dynamat Xtreme and Superlite. Should I consider applying this to the interior while it is stripped? Basically I am a little confused as to the sequence of work on the interior now that the rust issue has (for the most part) been taken care of. This is my first real restoration.
When I do come to paint the car, I guess it would be wise to paint the interior as it is already stripped? Also – looking for suggestions for color. The car was originally silver but has been badly repainted blue at some point (engine bay and interior are still silver). I’m thinking of a gunmetal gray with bronze wheels and all trim powder coated black. Any thoughts?
At the moment I do not have the time or space for a frame up restoration (I am very aware that it would be a better way to do it but it’s not an option at this point so I don’t see the point in talking about it). So the order in which I am planning to do things is:
·         Frame/Rust removal
·         Brakes
·         Suspension
·         Exhaust
·         Bodywork
·         Paint
·         Engine (L28 is running well but at some point I may consider a rebuild)
Apologies, this post is very messy, I tried my best to organize my questions but I want to do things in a logical order and avoid repeating or missing steps in the restoration. Any help would be appreciated.
In the current state (pictures above) I would pull the motor and transmission now.  Pretty easy to get all that out of the way now. Your going to paint the engine bay and the steering rack will be accessible.  Front suspension would be easier without the weight too.
My $.02.
There's lots of ways you can tackle it but if your interior has been removed then that's as good as any place to start.  Remove all the sound deadening tar that originally came on the car, it was installed over bare metal and sometimes you'll find big patches of rust under it. Clean all the interior surfaces with wax&grease remover, scuff it up well with 80 grit and clean it again before priming, Por15 can work well if you follow the instruction exactly but for my money you can't do better than 2 part epoxy primmer.
By the way, that's a good choice on colour and wheels;)
Thanks for the replies.
Ok, so does this make sense as a rough plan moving forward:
- Once floor pan and frame rail work is done, undercoat using POR-15 (A specialist is doing this, not me, so I believe POR-15 is a good way to go).
- I'll clean up the interior and get it ready for primer. Dynamat Xtreme on top of primer.
- Take care of some bodywork such as shaving and filling, fix any dents, etc.
- Pull motor and transmission and send body for media blasting.
- This would be a good time to do brake and suspension work.
- Paint exterior and engine bay.
- Assembly.
Couple of questions:
1. grannyknot - what epoxy primer do you recommend for interior application?
2. grannyknot - Beautiful car, is that an original color? If so what's the code/name?
3. After media blasting, am I right in saying I need to get the car to primer straight away? (In my experience after sandblasting, steel rusts extremely fast as it is so exposed)
4. Is the interior typically installed over primer, or is there a finish coat applied on the interior aswell? I normally see cars being painted with the interior taped and covered so only the exterior and engine bay receive color?
Again apologies if some of these questions are pretty obvious to some, as I said, it's my first restoration and I'm keen to learn the process.
If you don't mind doing some reading, there are several extremely well documented restorations on this forum that have all the information you are asking for in great detail. We are all very helpful people here, but having us regurgitate all of this info in every new rebuild thread is overkill. Look at Grannyknots rebuild thread, check out Hazmatt's awesome thread and maybe even mine. Lots of info that will answer all your questions. Or at least help refine your questions...
Fair enough - I know it is pretty annoying to have to keep repeating oneself!
#3. Yes
#4. Either way.  Interior finish coats look great for resto pictures but not absolutely necessary IMO, Especially if you are going to Dynamat the interior.  But a lot of folks do that because it complete's the process to a high standard. Whatever you are doing, do it well kind of thing.
And, no apologies needed. It makes us feel useful and smart........sometimes......maybe.......or not......
If you follow Wheee! deja vu restoration you will see a clinic on the best way to restore. from that you can decide where to go, follow that order and you have the best it can be.
...blush...
all of my tricks I stole from the masters before me on this forum....
What about me?  I still lurk around here ya know!
Knock yourself out!
Edited by ksechler
There are quite a few 2k epoxy primers brands, any good paint shop can put you on to them. But once you have picked a brand stay with it for all the different coats, don't mix and match different companies, it's just safer.
Thanks, not original, Jeep colour, anvil grey.
If you are going to media blast then I would say do it all at once, interior and exterior, then prime the inside and outside at the same time.   Personally I would skip the POR15, it won't work well with standard primers and paint and won't offer more protection than a properly prepared body with standard products
Here is a resource for paint:
https://www.paintforcars.com/auto-paint-car-paint-automotive-paint.html
This is what is used.  For sequencing I painted the interior and underbody.  This included primer, finish color and undercoating the bottom.  Then I partially reassembled the car (fuel lines, suspension, brakes).  The suspension had been restored (by me) previously.
  • Who's Online   2 Members, 0 Anonymous, 1,325 Guests (See full list)
