2 minutes ago, Patcon said:
I don't have any extra but I could trace one or scan it if that would help.
I have one which has been with a fabricator for months. He says that he cannot find the correct material to cut them out of. I ordered 50 of them and then planned to have then zinc plated, but I am now on plan "B".:unsure:
2 minutes ago, Namerow said:
I think they're just generic, auto body shop shims. Should be available for pennies at a nearby shop in your town.  Does anyone have evidence that Nissan used body shims in the assembly of Z's?
These shims are specific to the three bolt pattern of the hinges. There were one or two in the top hinge and sometimes in the lower hinge as well. I currently have body shop shims in place, but that is not correct.
I might have a fabricator here who could cut them out. Not sure on cost...
I am going to take the one I have to our High School machine shop Tech class. They have a plasma cutter and are always looking for projects. The metal may be too thin for that process, I don't know. I will let you know if that does not work our.
Sounds good
