JLPurcell Posted February 20, 2018 Author Share #13 Posted February 20, 2018 1 hour ago, Lumens said: My 72 came with that bracket and the wiring installed. I just figured all the 72's here came that way. I know that the car was pre-wired for the fuel pump, but I was not aware that the bracket was part of the preparation package. I will have to have someone else weigh in on this one. I am also wondering if I can run both my mechanical and an electric fuel pump. I know you could blank out the mechanical, but I want the original pump to stay in the system for appearance. Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-542847 Share on other sites More sharing options...
GV Z Car Posted February 20, 2018 Share #14 Posted February 20, 2018 fyi....The picture that I posted above shows a bracket I pulled from a 1974 260...(that I installed on my 71 240). Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-542850 Share on other sites More sharing options...
JLPurcell Posted February 20, 2018 Author Share #15 Posted February 20, 2018 Picked up the used bracket and a NOS fuel pump. Another project! 1 Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-542859 Share on other sites More sharing options...
Mark Maras Posted February 21, 2018 Share #16 Posted February 21, 2018 7 hours ago, JLPurcell said: I know that the car was pre-wired for the fuel pump, but I was not aware that the bracket was part of the preparation package. I will have to have someone else weigh in on this one. I am also wondering if I can run both my mechanical and an electric fuel pump. I know you could blank out the mechanical, but I want the original pump to stay in the system for appearance. You can run both pumps. By 74 (maybe earlier) Nissan used both pumps to try to resolve a fuel percolation, vapor lock, problem with limited success. 1 Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-542880 Share on other sites More sharing options...
JLPurcell Posted February 21, 2018 Author Share #17 Posted February 21, 2018 1 hour ago, Mark Maras said: You can run both pumps. By 74 (maybe earlier) Nissan used both pumps to try to resolve a fuel percolation, vapor lock, problem with limited success. Mark, thanks. Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-542897 Share on other sites More sharing options...
siteunseen Posted February 21, 2018 Share #18 Posted February 21, 2018 Mr Purcell I don't know if you've seen this before but it's a pretty good write up, just an FYI. http://jarvas240z.blogspot.com/2013/01/electric-fuel-pump-installation.html 1 Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-542919 Share on other sites More sharing options...
esmit208 Posted February 22, 2018 Share #19 Posted February 22, 2018 On 2/21/2018 at 8:35 AM, siteunseen said: Mr Purcell I don't know if you've seen this before but it's a pretty good write up, just an FYI. http://jarvas240z.blogspot.com/2013/01/electric-fuel-pump-installation.html THANX SITE. As the reassembly of mine transitions write-ups like this will help us all avoid MAIN HARNESS BBQ's! 1 Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-543009 Share on other sites More sharing options...
JLPurcell Posted February 24, 2018 Author Share #20 Posted February 24, 2018 (edited) On 2/20/2018 at 9:12 AM, Mike W said: There are actually a couple of these for sale on eBay. One with the same part number that HS30-H mentions in his post: https://www.ebay.com/itm/Datsun-Z-fuel-pump-mount-mounting-bracket-17033-E4200-USED/382363930288?hash=item5906aa8eb0:g:zwQAAOSwkLhaG5cd&vxp=mtr And another that is identical to the one on my late manufacture 260Z: https://www.ebay.com/itm/77-78-Datsun-280Z-fuel-pump-bracket-OEM-used-painted-clean/382374963056?hash=item590752e770:g:RAEAAOSwHNxaTa88&vxp=mtr Ironically both from the same seller. Looks like Nissan changed the design of this over the years. Mike. Received the bracket today. Bent, no rust, easily straightened, but the first thing I did was drop it off at a custom rubber stamp vendor to have a stamp made to replicate the part number on the bottom of the bracket. Once that is complete I will straighten, sand blast, powder coat, and stamp the part number back on it. It will then be ready for the NOS pump. Will post more once project moves along. Edited February 24, 2018 by JLPurcell 4 Link to comment https://www.classiczcars.com/topic/59571-bracket-for-1972-electric-fuel-pump-upgrade/?page=2#findComment-543144 Share on other sites More sharing options...
