S30Driver Posted March 18, 2018 Share #37 Posted March 18, 2018 Impressive results for sure! The mikuni's look great. Include a pic of the valve cover after. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-544855 Share on other sites More sharing options...
duffymahoney Posted March 18, 2018 Author Share #38 Posted March 18, 2018 1 minute ago, S30Driver said: Impressive results for sure! The mikuni's look great. Include a pic of the valve cover after. Not done with the cover yet. I will eventually do my head and my ford bronco oil pan and then my harada manifold. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-544856 Share on other sites More sharing options...
dutchzcarguy Posted March 18, 2018 Share #39 Posted March 18, 2018 9 hours ago, Patcon said: Oh I don't know. You can never have too many tools!!! OHH.. yes you can... if your garage gets to small... and you store carparts in your home.. I TELL EVERYBODY IT'S ART IN MY LIVING.. 2 Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-544859 Share on other sites More sharing options...
Patcon Posted March 18, 2018 Share #40 Posted March 18, 2018 2 hours ago, dutchzcarguy said: OHH.. yes you can... if your garage gets to small... and you store carparts in your home.. I TELL EVERYBODY IT'S ART IN MY LIVING.. You mean you're not supposed to store car parts in your home?????? Don't tell my wife that! 1 Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-544867 Share on other sites More sharing options...
Captain Obvious Posted March 18, 2018 Share #41 Posted March 18, 2018 Very nice. Those results are fantastic. So how do the results differ from straight up bead blasting? In other words... Would the parts have looked much different if you were using s standard bead blasting cabinet? Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-544873 Share on other sites More sharing options...
240260280 Posted March 18, 2018 Share #42 Posted March 18, 2018 1 hour ago, Captain Obvious said: Very nice. Those results are fantastic. So how do the results differ from straight up bead blasting? In other words... Would the parts have looked much different if you were using s standard bead blasting cabinet? original, bead, vapour Vapour peens and cools at same time. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-544884 Share on other sites More sharing options...
duffymahoney Posted March 18, 2018 Author Share #43 Posted March 18, 2018 I don’t think vapor affects the aluminum at all. I think it just picks the dirt out of crevices. It won’t pull off silicone or gaskets very easily. Doesn’t affect zinc. Doesn’t damage anything Today I tried way less glass and had the same results. This valve cover was rough. Looks pretty awesome now. Trying to get the appearce to be uniform is time consuming. I just gave up. I plan on doing 3 covers. One wrinkle red, wrinkle black and this one and decide which I like the best. It it just barely big enough for this cover. The head will be tough to fit and get the ends done. Shouldn’t be that bad though. 1 Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-544887 Share on other sites More sharing options...
duffymahoney Posted March 23, 2018 Author Share #44 Posted March 23, 2018 I worked on my space e31 head and another Mikuni 44. Sadly the head has some severe pitting on number 1 and 6. It was covered in carbon. So you couldn’t see it. Strange. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-545450 Share on other sites More sharing options...
duffymahoney Posted March 23, 2018 Author Share #45 Posted March 23, 2018 (edited) I added this 120v solenoid for the air. So when i use my foot pedal it turns the air and the slurry pump on. Works so much better this way. I had great luck keep the slurry mixed by every 30 seconds or so pointing the jet to the bottom and mixing up the slurry mix. I could tell the slurry would be different for a bit. Edited March 23, 2018 by duffymahoney 3 Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-545451 Share on other sites More sharing options...
duffymahoney Posted March 29, 2018 Author Share #46 Posted March 29, 2018 I got another set of rough 44s. Strangely they were fully functional though. They came out amazing. Now off to have them rebuilt. I assume it gets everywhere and will need to be thoroughly cleaned and sonic bathed. 3 Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-545980 Share on other sites More sharing options...
grannyknot Posted April 18, 2018 Share #47 Posted April 18, 2018 Duffy has encouraged me to add some pics and results of the wet blaster I just made following his plans, I wanted something a little bigger for larger objects but that can still be dismantled easily for set up and storage, most importantly I wanted it cheap. I have about $425 into it so not too bad. The hopper is made from some 16ga stainless steel sheet, I manged to get the whole hopper out of a 24"x 48" piece, the frame is 3/4" angle iron and the cabinet is some 5/8th plywood I had on hand. 4 cans of Rocker Guard to seal the wood inside and out and the inside is also covered 1mm thick pond liner. The pump I picked up is and old water circulation pump for a large heating system, it might be completely wrong for the job but won't find out until my outside tap unfreezes. I'm hoping that if the pump is a really high pressure unit that I may not need to add an air line, we'll see, it's easy enough to add it later. The LED lamp is a water proof outdoor unit with 2,400 lumens, $36 for two lamps. 3 Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-547665 Share on other sites More sharing options...
Patcon Posted April 19, 2018 Share #48 Posted April 19, 2018 Very nice! What are the dimensions of the main grid? How large is the entry door? I was looking a building a new blasting cabinet that would take larger items. Lots of good ideas here... Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=4#findComment-547687 Share on other sites More sharing options...
