duffymahoney Posted April 22, 2018 Author Share #61 Posted April 22, 2018 I am using 170-325 glass bead. Tiny stuff Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-547852 Share on other sites More sharing options...
Worx10r Posted August 26, 2018 Share #62 Posted August 26, 2018 GREAT Build! I've been searching the internet for someone that has actually build a quality unit that works so i'd like to thank you {Duffymahoney} for all that you have done for my project. I may have missed it but I am wondering where you bought your "blast" gun? Thanks again Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556233 Share on other sites More sharing options...
duffymahoney Posted August 26, 2018 Author Share #63 Posted August 26, 2018 It’s some amazon nozzle for wet blasting with a pressure washer and sand. It’s probably the worst part of my system. I should try and find a better one. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556237 Share on other sites More sharing options...
Worx10r Posted August 27, 2018 Share #64 Posted August 27, 2018 So will any nozzle work or does it need to be a wet nozzle? Thank you, please let us know if you come up with a better nozzle. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556305 Share on other sites More sharing options...
duffymahoney Posted August 27, 2018 Author Share #65 Posted August 27, 2018 1 minute ago, Worx10r said: So will any nozzle work or does it need to be a wet nozzle? Thank you, please let us know if you come up with a better nozzle. I will probably continue to use mine. I honestly don't know what nozzle would be the best. Vapor honing technology uses a chinese one you can find on alibaba. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556306 Share on other sites More sharing options...
Patcon Posted August 27, 2018 Share #66 Posted August 27, 2018 Check this site out. I bought some gloves from them for my blasting cabinet. They are really long, big enough even for my hands and nicely lined. They sell all kinds of blasting stuff www.tptools.com Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556326 Share on other sites More sharing options...
duffymahoney Posted August 30, 2018 Author Share #67 Posted August 30, 2018 Well I killed my first slurry pump. It was a 70$ amazon one that is no longer available. This one looks indentical and has the same stats but I like how easy it is to take apart, I will try to take better care of it and flush it after every use. I had about 20 hours on the first one. Also I have 3 nikki fuel pumps to blast and a FET triple intake. Should be fun! Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556454 Share on other sites More sharing options...
240260280 Posted August 31, 2018 Share #68 Posted August 31, 2018 I was thinking that a sewage pump would be more robust Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556482 Share on other sites More sharing options...
grannyknot Posted August 31, 2018 Share #69 Posted August 31, 2018 1 hour ago, 240260280 said: I was thinking that a sewage pump would be more robust The glass beads aren't that heavy but once they are stationary they don't get moving easily without some agitation, I think the sewage pump would have a hard time lifting them up. I'm using the hopper design the same as Duffy with the glass beads above the pump and I still have to blast the nozzle down into the pile of beads to get them mixed up so they can be sucked down to the pump. 1 Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556487 Share on other sites More sharing options...
duffymahoney Posted August 31, 2018 Author Share #70 Posted August 31, 2018 (edited) I deal with pumps for a living. Any high end aerator style bump would be good. The amazon one I got is about perfect. I have a super high end water one that I could use. It’s just a giant overkill. Edited August 31, 2018 by duffymahoney Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556489 Share on other sites More sharing options...
Patcon Posted August 31, 2018 Share #71 Posted August 31, 2018 "Giant Overkill" is good! sort of like reaching for a bigger hammer... Did you look through the link I posted earlier? Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556512 Share on other sites More sharing options...
duffymahoney Posted August 31, 2018 Author Share #72 Posted August 31, 2018 5 minutes ago, Patcon said: "Giant Overkill" is good! sort of like reaching for a bigger hammer... Did you look through the link I posted earlier? There are tons of websites for blasting stuff. Very little actually has to do with vapor/ water honing or whatever people call it. I got lucky and the vapor honing guy gave me some secrets. That's why mine works so well. Next best thing would be some sort of slurry pre mix machine. You could go nicer on the pump, but all pumps wear out. Something that could be rebuilt would be nice. The reason I picked this pump, is because it's easier to pull apart then my last one. Link to comment https://www.classiczcars.com/topic/59657-diy-home-built-vapor-blasting-honing-cabinet-wetblasting/?page=6#findComment-556514 Share on other sites More sharing options...
