 Mostly just some of the products are different, the applications are very similar,
Permatex Aviation Form a Gasket or  Three Bond 1184
Moly 60/Honda 60 spline grease
Permatex Ultra Black sealant
RedLine Assembly Lube Paste, doesn't drip off, you can put the engine in storage for 10 yrs and it is still ready for start up.
Molly Slip Copaslip, copper based anti seize
  • 4 weeks later...
I use what most of the people use up there, just wanted to add;
Permatex Anti-Sieze.
Dow-Corning Telescopic Grease for brake caliper // pad parts
https://www.acrossinternational.com/Dow-Corning-53-Oz-Colorless-High-Vacuum-Sealing-Grease-Tube-DowGrease53oz.htm
Started using the DCTG after spending time restoring Honda SOHC4 brake calipers.
http://forums.sohc4.net/index.php/topic,56544.50.html
Gamma did some interesting research on the grease, and how it reacted to temperature in that thread. One tube lasts a long time.
On 4/3/2018 at 12:58 PM, 240260280 said:
Clevite Assembly Lube:
  1. Rocker Pivot Tops
  2. Rocker Arms (both contact surfaces and socket)
  3. Valve Tip
  4. Lash Pad (top, sides, and bottom)
  5. Cam Lobes
  6. Cam Rotating contact surfaces
  7. Cam Tower Surfaces
  8. Main Bearings (inside, and sides of thrust)
  9. Crank Rotating contact surfaces (main and rod)
  10. Rod Bearings (inside)
Just a word of caution for those new to assembling a cylinder head. From my engine shop guy. DO NOT use any sort of assembly
lube on your valve stems. This can definitely cause a valve to stick.
What? Does not compute, how can lubricant cause sticking?
 a search turned up that some "assembly" lubes may gum up (to thick additives for such a tiny area are not good) for the very small amount of lube that is in the valve stem/valve guide contact. Only a tiny bit of motor oil is needed for normal lubrication. consensus was regular motor oil is fine for assembly lube of the valve stem/valve guide.
