Neutral/4th gear/reverse light. Its detailed in the FSM, the only one you need is the reverse light switch. I am pretty sure the neutral is for the interlock mech that keeps the car from starting unless everyone is seated and buckled up. I got tired of reading it. the 4th gear switch maybe something with the ign advance. did not see it on 1st pass of the FSM. I did not see it in my online copy but was in the hard copy book I have.
Edited by Dave WM
For the trans and diff oil are there any recommendations?
I heard many prefer Redline MT90, synthetic 75w90.
Also read some go as high as 140 which may be a little much.
Has anyone used Lucas synthetic 75w90 or Valvoline synthetic?
Both are at the local parts store were the Redline will need to be ordered.
  • Who's Online   1 Member, 0 Anonymous, 1,404 Guests (See full list)
