Try turning the screw or bolt under the control valve located under the throttle body.  It is called the boost controlled deceleration device (BCDD).  It is a controlled leak around the throttle plate to reduce high manifold vacuum when the throttle valve snaps shut (usually under braking)
The screw turning is trial and error until you are happy with the way the rpms fall when stopping.
9 hours ago, Jdizz07 said:
Hi all,
Finally got my 76' 280Z going, but whenever the brake pedal is pressed the engine revs up to about 3000rpm. Any ideas? Hole in the brake booster? Brakes still work as usual.
Any ideas for a cheap fix?
Yes, that is the classic sign of a holed brake booster.  When you press the brake pedal you open up a vacuum leak.  People have been known to rebuild them.  Disassembly is actually shown in the FSM.  But most just replace them, with a reman.  They're hard to find, and quality is generally poor.  I don't think that you can get rebuild parts easily either.
Edit - a simple test would be to disconnect and block the vacuum hose to the booster, then press the pedal and see if the problem is there.  Whether RPM drop or rise depends on the size of the hole.
246, you're showing fixes for RPM hanging high while driving.  Pretty sure the OP is just sitting still, pressing the brake pedal.
Edited by Zed Head
My 260 had this issue, it was the brake booster that failed. The brake was significantly more difficult to push down when this happened.
I got it repaired at Power Brake Exchange in San Jose, took them a couple days to rebuild. They beadblasted it when I got it back.
  • Who's Online   2 Members, 0 Anonymous, 1,446 Guests (See full list)
