rear main/pan/rear side seals.
Clean it up real well with some brake cleaner, get it dry as a bone, then drive a bit. If you see oil ONLY around the rear of the pan gasket and if you see oil dripping down out of the trans weep hole, then its prob the rear main and or side seals.
Edited by Dave WM
https://www.classiczcars.com/topic/59861--/#findComment-547302
  • Who's Online   2 Members, 0 Anonymous, 1,366 Guests (See full list)
