3 hours ago, Dave WM said:
the drain pipe
Dave, where is this said pipe located exactly?
Different subject but I guess you don't have any oil leaks from the engine seals or pan? My front main I just recently replaced. But I still have a pan leak from the looks of it otherwise I would take mine on longer trips. Really, I guess I shouldn't worry so much about the small leaks.
Well if you just put in almost an thousand miles in a road-trip and the only thing that went wrong was that your condensate drain leaked, I'd say you're doing pretty good!
RCB, the drain tube is right below the HVAC assembly. A little left of center, like below the temperature control slider. There's a piece of rubber tubing attached to the evaporator box, and there's supposed to be a grommet in the transmission tunnel. The tube fits snug into the grommet and directs the water to the ground instead of the interior of the car.
def consider those side seals, that was what did it for me, dry as a bone back there now. you can do it with the trans installed, just work the side seal and pan gasket at the same time. Get the car up safely with plenty of room to work, take your time, clean the surfaces real well and follow the FSM on location. Think I mentioned before, don't let the sealant setup before reinstalling the bearing retaining block, or maybe use an anaerobic type of sealant (have not tried that myself but sounds like an excellent idea).
Ordered up some new jute (mac's) will use the old one as a pattern as it was pretty beat up where you heel rides on the floor board. The OE carpet looks pretty good, some of the rubber backing is missing and or cracking off. Would like to refurb that, may go with some kind of spray on flexable backing. Maybe plastidip spray.
Edited by Dave WM
