Howdy,
Anyone have a compatibility list or someone that sells carburetor hardware, (screws and springs and such) for round top Su Carbs?
I contacted Ztherapy, but they dont sell hardware out by itself. Been kinda scouring around online, and I cant seem to find anything...
Regards,
Rama
https://www.classiczcars.com/topic/59981-su-carb-hardware/
Try the Z Car Garage in San Jose. http://www.zcargarage.com
My buddy Andy is a mechanic there, he was saying that they don’t tell parts to the public, they only sell parts to cars that they work on in the shop. Maybe that stance has changed, I’ll shoot over some time and ask.
https://www.classiczcars.com/topic/59981-su-carb-hardware/#findComment-548789
Here's an old list I have saved.  You'll probably want to google the numbers to make sure they are compatible with the 240Z, some are for the 2000 Roadster.  I got lucky and found a complete set of SUs on craigslist I rob parts from occasionally.
Part Name Part Number Price (each) Available?
Gasket Kit (2) 16455-H2310 $3.30 YES
N-17 Jet Needle (2) 16354-25611 $8.81 YES
Inlet Screen/Filter (2) 16098-73401 $.65 YES
Fuel Pipe (2) 16356-25610 $13.68 YES
Banjo Bolt (2) 16108-18010 $1.69 YES
Float (2) 16061-E4310 $11.90 YES
Nozzle, Front 16355-25610 $19.11 YES
Nozzle, Rear 16355-25611 $17.99 NLA
Float Valve (2) 16101-25610 $10.06 NLA
Float Spring/Lifter (2) 16325-10400 $1.38 YES
Suction Spring (2) 16346-25610 $2.54 NLA
Screws, for Domes and Float-chambers (16) 16129-73013 $.24 NLA
Washers, for Domes and Float-chambers (16) 23502-30000 $.33 NLA
https://www.classiczcars.com/topic/59981-su-carb-hardware/#findComment-548799
oh wow, thanks siteunseen! I actually grabbed some flat top's yesterday for free from craigslist. I was after the balance screws after one of mine apparently rattled off the car ? I had to pull one off my 3 screw, but I needed that for another car.
That and the Dome Screws, hopefully they are interchangeable for the round tops, if they are at least they'll serve some purpose ?
https://www.classiczcars.com/topic/59981-su-carb-hardware/#findComment-549051
On 5/10/2018 at 8:39 AM, SteveJ said:
I think the dome screws will interchange. I seem to remember scavenging screws from my collection of flat top carburetors when I swapped over to the early carburetors.
I ended up just doing this, there are lots of little Philips bolts on flat tops that can be salvaged, as well as the screws for the choke lever. Someone local was throwing them away, worked out for my needs!
https://www.classiczcars.com/topic/59981-su-carb-hardware/#findComment-549640
  • Who's Online   1 Member, 0 Anonymous, 1,428 Guests (See full list)
