kstewart Posted May 7, 2018 Share #1 Posted May 7, 2018 In my daily perusal of CL I ran across an interesting photo in this posting. Photo 22 shows what looks like a crank trigger wheel on a very stock looking 1973 240Z with supposedly 66k miles on the clock. It does have an aftermarket coil, but the smog pump, carbs, and distributor are still in place on the pretty unmolested looking engine. Any ideas on what we are looking at or why a carb car with a distributor would need a crank trigger? My only guess is there's some kind of different ignition timing going on somewhere. I'm starting an L28E build with Megasquirt for my 240Z and am looking at crank trigger options. Thanks, K Link to comment https://www.classiczcars.com/topic/59991-l-series-crank-trigger-question/ Share on other sites More sharing options...
Zed Head Posted May 7, 2018 Share #2 Posted May 7, 2018 Looks like a 1981 turbo engine damper. Might even be an L28 in that 240Z. The wheel is there but where's the sensor? See picture. Nissan used the crankshaft mounted wheel for one model year then went to a distributor based system. But there are a few aftermarket systems out there. Link to comment https://www.classiczcars.com/topic/59991-l-series-crank-trigger-question/#findComment-548899 Share on other sites More sharing options...
Zed Head Posted May 7, 2018 Share #3 Posted May 7, 2018 Here's one option. You'll probably have to contact him, I can't figure out what, exactly, he's selling. He tends to make good products though. Web-site skills, not so hot. http://hokeperformance.squarespace.com/store/l-series-crank-angle-sensor-kit Link to comment https://www.classiczcars.com/topic/59991-l-series-crank-trigger-question/#findComment-548900 Share on other sites More sharing options...
kstewart Posted May 7, 2018 Author Share #4 Posted May 7, 2018 Thanks Zed Head, That's what I'm planning on doing at the moment. A little $$, but seems like a good quality piece. Jegs has the Professional Products reproduction euro style dampers that I'm planning on attaching it to. I didn't realize that the turbo had come with a crank angle sensor, interesting. Still doesn't explain why it's on a 1973 240Z with "one owner 1973 Datsun 240 Z with the original six cylinder factory four-speed, 66,212 original miles" ? Link to comment https://www.classiczcars.com/topic/59991-l-series-crank-trigger-question/#findComment-548915 Share on other sites More sharing options...
Zed Head Posted May 7, 2018 Share #5 Posted May 7, 2018 Probably just swapped an 81 turbo damper on to his L24. They'll interchange. Link to comment https://www.classiczcars.com/topic/59991-l-series-crank-trigger-question/#findComment-548916 Share on other sites More sharing options...
