It's clear from the scratch marks on the little metal tabs of that switch that someone has opened that thing up in the past. I'm sure it's all related.
Maybe the wire's solder joint was weakened by that process, Maybe they took it off completely during that process and didn't do a good job of putting it back on. Maybe the headlight side rocker inside the switch was burned beyond recognition so they swapped the one from the running lights over. There might not even be a rocker on the running light side if that's the case. Maybe they took that wire off intentionally to use a separate mounted switch somewhere else.
Just thinking out loud as to why that switch and wiring is the way it is now. I think you have identified the "what". I'm just musing about the "why".  :)
Hey Captain thanks for your post. I was the one that opened the circuit because head lights were not working so I cleaned the carbon built up. Now headlights are working. I was just trying to figure out the green and white wire. See my previous post. Thanks for any advise
Here is a photo a wire diagram I have used for sometime now. Here is a section that shows the Hazard and ignition switch area and shows a Green/white wire. Maybe it will help. Could that connector go to the Flasher?
Edited by 7tooZ
  • Who's Online   2 Members, 0 Anonymous, 1,505 Guests (See full list)
