Currently no dash lights no park lights. That connector located under the dashboard behind the fuse circuit. Check the continuity from that connector to the white and green cut wire in question from my original post and there’s a continuation. Also there’s a continuity with the blue/green and the missing wire on the second picture when combo switch is in park or on
