Regarding replacing the hood:  Early cars are known to have slightly different hoods.  You should try to save it if you can if you ever plan on selling the car.  Crazy Z people know about the different hood and will want it to be on the car vs. the later one.
Yes, the 69 hood is different in several areas. I compared it to my later Series 1( #8701) and Series 2 (#23381). The most striking different is that reinforced piece at the upper corners. The 69 hood doesn't have them. So yes, we're trying to save the hood of #187. As you can see, the front lip of the hood was originally bent down and in, and shows a lot of fillers once the paint was stripped. cbc769144a301eed8394224baf9a83af.jpg98a127fe0fd0d61cc13279c981749062.jpg7f36e405a508b5275440b2231bb3d20a.jpg0814430c83c4ff8fdd607bc56190a227.jpg
Sent from my SM-G975U using Tapatalk
  • 2 years later...
