We make and sell the following parts:
  • 240/early 260 frame rails - these start 9 inches in front of the firewall and end were the OEM version does. It covers about 2/3 of the TC rod box and are made from 13 gauge steel. Sold as single or as a set. Can be used as a complete replacement or a slip over to existing rails.
  • 240 optional rear rails -  a personal design piece that was never offered. It connects the under seat rails with the rear of the car. Sold only as a set. A stock rear sway bar will not fit but a Suspension Tech will
  • 280/late 260 rails - made to match the contours of the 280 floor pan. Sold as a pair or a single rail. Same thickness as the 240 rails. These will not fit aftermarket 280 floor pans which are flat. Our 240 rails can be used.
  • Sway bar plates - used to keep the engine bay rails and fenders from separating under high stress when a larger than stock sway bar is used.
  • Single point jack plates - used if you want to change both tires on a side using only one jack point.
  • 240/early 260 seat brackets - replacement mounts sold by side
  • Who's Online   2 Members, 0 Anonymous, 1,429 Guests (See full list)
