Next question... From all I've been able to glean from my friend google the Hitachi 3 and 4 screw round tops are HS style SU's. Looking at different listings for velocity stacks there are several HSn listings, HS2, HS4, HS6 and HS8! I can't find anywhere that lists what the HSn is for the Hitachi 4 screw round top SU's. Would any of you 240Z 4 screw SU experts know what the HS number is? Or if the Hitachi's even fit this HSn nomenclature?
https://www.classiczcars.com/topic/60086-velocity-stacks/#findComment-549989
Hopefully someone will find all this info useable. The HJG46W-4 is the carburetor for the 71 Z. This carburetor along with all 240z / 260Z's is listed as having a bore of 1.811in (46mm), this must be at the throttle valve plate as I used my micrometer and measure 43mm at the carburetor inlet. It does appear from this diagram that the throat? is widened on the intake manifold side of the venture. None of this info really helps to answer any of my questions in this thread. Hopefully someone with the stock air cleaner can measure the height of the integrated velocity stacks and post in this thread.
Who knew it would be this hard to figure out which stacks would be compatible with these SU's beyond what's available through MSA!
https://www.classiczcars.com/topic/60086-velocity-stacks/#findComment-550045
  • Who's Online   2 Members, 0 Anonymous, 1,433 Guests (See full list)
