jonbill Posted December 3, 2018 Share #61 Posted December 3, 2018 I've used Holley Red and Blue pumps and I found them both ferociously loud and rather unreliable (correctly positioned at the level of the bottom of the tank). I wouldn't recommend them. I'm currently using an old quiet Bosch 4 bar diesel pump out of my BMW. I've got an Aeromotive FPR that regulates it down to 2.5 psi and I'm very happy with it.I haven't read the whole thread but I read the first post and I'd say if it's going lean almost immediately at 3k in 3rd when you apply load, I don't think it's the fuel supply, it would take a few seconds to use up the float chambers. I think your needles are too lean. Are they the ones that came with the carbs?Apologies if you've been over this. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562943 Share on other sites More sharing options...
Mark Maras Posted December 3, 2018 Share #62 Posted December 3, 2018 Here's a remote possibility that I experienced long ago. Similar symptoms, different vehicle. After much testing and frustration, I found the culprit to be an old rubber fuel line that had delaminated inside and had essentially made a flapper valve that closed when the fuel demand was high. I had to cut the hose lengthwise to discover how it worked. I could blow through the line in both directions and it seemed to be clear but the fuel would force its way behind the delaminated piece, push it into the mainstream and block the flow. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562944 Share on other sites More sharing options...
Mark Maras Posted December 3, 2018 Share #63 Posted December 3, 2018 4 minutes ago, jonbill said: I've used Holley Red and Blue pumps and I found them both ferociously loud and rather unreliable (correctly positioned at the level of the bottom of the tank). I wouldn't recommend them. I'm currently using an old quiet Bosch 4 bar diesel pump out of my BMW. I've got an Aeromotive FPR that regulates it down to 2.5 psi and I'm very happy with it. I haven't read the whole thread but I read the first post and I'd say if it's going lean almost immediately at 3k in 3rd when you apply load, I don't think it's the fuel supply, it would take a few seconds to use up the float chambers. I think your needles are too lean. Are they the ones that came with the carbs? Apologies if you've been over this. It might be time to pull a needle to identify them and cross them off the list of possibilities. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562945 Share on other sites More sharing options...
MY1PATH Posted December 3, 2018 Author Share #64 Posted December 3, 2018 (edited) 37 minutes ago, jonbill said: I've used Holley Red and Blue pumps and I found them both ferociously loud and rather unreliable (correctly positioned at the level of the bottom of the tank). I wouldn't recommend them. I'm currently using an old quiet Bosch 4 bar diesel pump out of my BMW. I've got an Aeromotive FPR that regulates it down to 2.5 psi and I'm very happy with it. I haven't read the whole thread but I read the first post and I'd say if it's going lean almost immediately at 3k in 3rd when you apply load, I don't think it's the fuel supply, it would take a few seconds to use up the float chambers. I think your needles are too lean. Are they the ones that came with the carbs? Apologies if you've been over this. A few seconds? I think all of 1st and 2nd gear make up a few seconds. We're talking about Wide Open Throttle between shifts. 32 minutes ago, Mark Maras said: It might be time to pull a needle to identify them and cross them off the list of possibilities. 34 minutes ago, Mark Maras said: Here's a remote possibility that I experienced long ago. Similar symptoms, different vehicle. After much testing and frustration, I found the culprit to be an old rubber fuel line that had delaminated inside and had essentially made a flapper valve that closed when the fuel demand was high. I had to cut the hose lengthwise to discover how it worked. I could blow through the line in both directions and it seemed to be clear but the fuel would force its way behind the delaminated piece, push it into the mainstream and block the flow. All good suggestions but I did a test where I killed the engine when it starved and checked the bowls, they were were drained significantly. That points to there not being enough fuel going to the carbs. I ran a snake down every hose, hardline and fuel rail. I came up with zero restrictions. Edited December 3, 2018 by MY1PATH Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562948 Share on other sites More sharing options...
Zed Head Posted December 3, 2018 Share #65 Posted December 3, 2018 21 hours ago, MY1PATH said: Yep pump does not move enough. I also watched it free flow pump. Freeflo (tank>pre-filter>pump> 4ft hose>can) pumping from the tank to a 5 gallon can took about 12 min to fill = about 25 GPH (Airtex E8251 rated @ 30 gph) 21 hours ago, MY1PATH said: So I'm going to look at other pumps now. Holley Red 12-801-1 comes to mind first (Flows 97 GPH free flow and 71 GPH at 4 psi) but I'm open to alternatives like the Sniper 80000100 (Holley) with the same specs as the red but half the price... Your free-flow test seems to show that the pump flows fine. 25 versus 30. 25gph is a lot of fuel. I don't think anyone here has an engine that could burn that much. If you do decide to get a new pump, I'm with jonbill on the brands. Get an OEM brand, without the hypey name. Most of the old brand names like Holley have been sold and the quality level minimized for profits. You're buying an expensive name on a cheap product. "Sniper"? What does that have to do with cars and fuel? Hype. I didn't read the whole thing either but where is the pump mounted? Was the flow test with it mounted in its normal spot? Position can affect performance. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562951 Share on other sites More sharing options...
Mark Maras Posted December 3, 2018 Share #66 Posted December 3, 2018 Many Z owners have found the pumps from the 1st gen. Mazda RX7s (1980ish) are nearly silent and put out the proper pressure for carbs. Less than $50.00 at RockAuto. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562952 Share on other sites More sharing options...
Zed Head Posted December 3, 2018 Share #67 Posted December 3, 2018 1 hour ago, Mark Maras said: found the culprit to be an old rubber fuel line that had delaminated inside and had essentially made a flapper valve that closed when the fuel demand was high. I had to cut the hose lengthwise to discover how it worked. I had this same type of problem on a lawnmower. I think the hose delaminated because I had been using starter fluid to start the mower and overspray got on the hose, swelling it. Still, same effect. It would start but lean out and die after a few minutes. Not obvious by eye. Don't forget that the inlet side of the pump is under suction. 1 Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562953 Share on other sites More sharing options...
GGRIII Posted December 3, 2018 Share #68 Posted December 3, 2018 8 hours ago, Captain Obvious said: Cool. Glad to hear you are narrowing in on the root problem. So if you measured 25 GPH with the only restrictions in the line being a filter and a couple feet of hose, then I can certainly believe that number will go down even further when you have all the piping in place. And then there's the fact that some (most?) fuel just get's routed back to the tank. @GGRIII has gone through two different electric pumps in his car. Don't remember which ones they were, but I'm thinking one of them was the Holley red? I do know that he pulled the first pump and replaced with a second, but I don't remember if it was a delivery issue, or simply because the first pump was so durn loud. Hopefully he'll see the tag and chime in here to provide some input. I started out with a holley red but it was just way too loud. I switched to the Carter and it is a little better but not much. I have never had any issue with fuel delivery affecting performance with either pump. I like the carter design. It is hermetically sealed so the motor is cooled by the fuel. That may be what also makes it a tiny bit quieter. Do be prepared to hear them though. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-562975 Share on other sites More sharing options...
MY1PATH Posted December 5, 2018 Author Share #69 Posted December 5, 2018 On 12/3/2018 at 11:02 AM, Zed Head said: Your free-flow test seems to show that the pump flows fine. 25 versus 30. 25gph is a lot of fuel. I don't think anyone here has an engine that could burn that much. Yes, but it's just that "Free flow" not under pressure what if I run the same test again right before the fuel rail and with the increased restriction I only get 5 GPH. It only trickles back to the gas can on the return side. Plenty of vehicles can drink over 5 GPH, I think the 4.5 PSI flow rate is too low... Look if you read the whole thread and can still think of a good reason why its not the pump let me know. Correct AFR's are at any RPM just not for sustained periods of heavy load (takes multiple gears to drain the carbs) All hoses are new all hoses , hardlines and rails have been snaked fuel tank is out of the equation and problem still persists Richening the needles brings the problem sooner. (hmm adding more fuel makes me run out of fuel faster) Float valves have been addressed and flow more than stock.... Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-563096 Share on other sites More sharing options...
Zed Head Posted December 5, 2018 Share #70 Posted December 5, 2018 8 hours ago, MY1PATH said: Yes, but it's just that "Free flow" not under pressure what if I run the same test again right before the fuel rail and with the increased restriction I only get 5 GPH. It only trickles back to the gas can on the return side. Plenty of vehicles can drink over 5 GPH, I think the 4.5 PSI flow rate is too low... Could be. Back pressure can make a difference, for sure. If a new pump doesn't fix it, at least you'll have a spare pump. Always good to have spares. I asked about pump position because sometimes people put the pumps in the engine bay. That creates a long path to suck on for the pump. The electric rotary pumps like to have the inlets supplied by gravity. They don't like to suck. I just saw that yours is back by the tank, so that's good. The pre-filter can cause problems also if it's too fine. Too hard to pull. The mechanical cam eccentric actuated pumps have been used for years. That pump alone should supply what the carbs need. Are you getting side-tracked, maybe? You might go all the way back to 1971, remove the pre-filters, use only the head-mounted pump, and a high-flow filter, or just the banjo-fitting screens. Sometimes we're overprotective. Probably fine for a test and might tell you something. Back to basics. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-563109 Share on other sites More sharing options...
GGRIII Posted December 5, 2018 Share #71 Posted December 5, 2018 If you really want a Holley Red, I have one out in my garage. I ran it for about 200 miles then went for the Carter. I don't link the Carter was that much quieter, at least not worth the effort of changing it out. If you are interested we can work out the details. BTW what are you using for a restriction/regulator? I had CO modify a Holley non BP regulator to make it a bypass. I'm not sure that it is always working... That is on my short list of to do's when warmer weather gets back. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-563136 Share on other sites More sharing options...
jonbill Posted December 5, 2018 Share #72 Posted December 5, 2018 Could be. Back pressure can make a difference, for sure. If a new pump doesn't fix it, at least you'll have a spare pump. Always good to have spares. I asked about pump position because sometimes people put the pumps in the engine bay. That creates a long path to suck on for the pump. The electric rotary pumps like to have the inlets supplied by gravity. They don't like to suck. I just saw that yours is back by the tank, so that's good. The pre-filter can cause problems also if it's too fine. Too hard to pull. The mechanical cam eccentric actuated pumps have been used for years. That pump alone should supply what the carbs need. Are you getting side-tracked, maybe? You might go all the way back to 1971, remove the pre-filters, use only the head-mounted pump, and a high-flow filter, or just the banjo-fitting screens. Sometimes we're overprotective. Probably fine for a test and might tell you something. Back to basics.I'd agree. Definitely get a decent pump, get a decent regulator and see if you've still got a problem or not. If there's still a problem, at least you'll be sure where the problem isn't. Link to comment https://www.classiczcars.com/topic/60096-su-carbs-will-not-sustain-heavy-load/?page=6#findComment-563139 Share on other sites More sharing options...
