The long guide is factory curved, but that plastic piece is supposed to be attached to the window frame. Yours is broken. You will find the other side of it attached to a metal bracket riveted to the window frame.
Edited by zKars
https://www.classiczcars.com/topic/60107-window-guide/#findComment-550060
