Since I haven't seen your dehumidifier, correct me if I'm wrong, but don't most dehumidifier's have a drain hose option on the back?  A male screw in for a hose fitting.  It's there to bypass the tank and to route the collected water down a drain,  or in your case to the yard.
I was going to suggest this. Mine in my shop is routed outside to a drain
Yes the big ones do. This one is made for small bathroom size rooms 150sqft or less. It has a little tank that slides in the bottom.
I should probably put my big one out there, but I may put one of my extra WiFi cameras in there and not even half to move off the couch to check!
  • Haha 1
  • Who's Online   1 Member, 0 Anonymous, 1,598 Guests (See full list)
