The car did not always make this sound. My first step is to find out where the smoke is coming from.
In case you missed it here is what I did to the engine while it was out of the car
Engine Work done:
new fuel injectors
oil pan gasket
lashed valves
replaced EGR
new oil filter
rear main seal
pilot bushing
2 hours ago, gotham22 said:
I bought a car stethoscope to do that. Hoping to have time this weekend to troubleshoot.
A stethoscope won’t “hear” an exhaust leak. It is great for tracking down mechanical noises though, like that knock on the video.
A little story...
I had a 95 suburban that went in for an oil change. Well they forgot to refill the oil but I really couldn't prove it. It had a rod nock after that. A local racer told me to run 20w-50 in it. Quiet as a mouse. We ran it that way for a long time
  • Sad 1
Been slow progress but I wanted to send an update.  Oil pressure seems good.  Its around 20psi during idle. I also fixed the down pipe exhaust leak (noise is still the same).  Next I am going to do a compressions test and then check timing. Again thank you all for your help
  • 3 weeks later...
