siteunseen Posted November 19, 2018 Share #37 Posted November 19, 2018 I'm pretty sure you can short the two wires together and the gauge will go to FULL as a way to test the gauge it's self? Maybe more knowledgeable people will verify. It's been a lot of years since I did my '77 tank refurb. Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-561979 Share on other sites More sharing options...
Pmg Posted November 20, 2018 Share #38 Posted November 20, 2018 I actually have a new sending unit for my 77.. My gauge only reads half full, but it hasn't bothered me enough to drop the tank and replace the sending unit. Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-561997 Share on other sites More sharing options...
Captain Obvious Posted November 21, 2018 Share #39 Posted November 21, 2018 On 11/19/2018 at 6:58 PM, siteunseen said: I'm pretty sure you can short the two wires together and the gauge will go to FULL as a way to test the gauge it's self? That is correct. The gauge should read F if the sender wires are shorted together. Just make sure you're shorting the correct two wires together. Don't do something like accidently short your fuel pump wires together. Make sure you have the fuel gauge wires. 1 Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-562084 Share on other sites More sharing options...
siteunseen Posted November 21, 2018 Share #40 Posted November 21, 2018 Thanks Captain, I wasn't 100% on that. Another thing I'm not sure about but it seems like I've read where someone replaced the O-ring on a '77 sending unit through the the inspection cover in the hatch? Would/could the unit be replaced without dropping the tank? Thanks and have a good Thanksgiving. I see where it's cold up there, more than usual. Cliff Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-562156 Share on other sites More sharing options...
Captain Obvious Posted November 22, 2018 Share #41 Posted November 22, 2018 I haven't personally confirmed, but my understanding was that the 77-78 sender unit could be removed through the access hole in the rear hatch. I don't know about other years, but I believe 77 on you don't have to drop the tank (or even drain it) to do that kind of work. 3 hours ago, siteunseen said: Thanks and have a good Thanksgiving. I see where it's cold up there, more than usual. Thanks bud, and you too!! Yes, it got way colder way quicker than it's supposed to be here. In fact, we got a bunch of snow middle of last week, and it ended my Z driving season with very little warning. I thought I was going to get a couple more weeks, but they salted the roads. I guess there's still a possibility that if we get a couple non-freezing rainy days it could clean off the roads enough to at least take it out and get some gas so I can circulate some stabilizer. As it sits now, it was a big surprise... Tank is pretty much empty and there's no stabilizer in it. We were supposed to get just a dusting of snow followed by an inch of rain that would have washed away any salt they put down. But that's not what happened. Instead, we got four inches of snow and very little rain at the end of the storm. Roads are covered with salt and I got kinda stuck behind the eight ball. Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-562171 Share on other sites More sharing options...
Av8ferg Posted November 22, 2018 Share #42 Posted November 22, 2018 (edited) So, was able to pull my sending unit out on my 77 from the rear hatch. Before this discussion i thought they all we like this. I bought a new o-ring and locking ring when I put in it back in. I’ve read somewhere to be careful pulling off the wires from the unit as they can fracture at the connection easily. I didnt have a problem. I know they changed the deck lid configuration in the middle of 77. I have the deck lid that curves upward towards the taillight versus the standard flat deck (wish I had the flat decking) . Edited November 22, 2018 by Av8ferg Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-562172 Share on other sites More sharing options...
dmorales-bello Posted November 22, 2018 Share #43 Posted November 22, 2018 12 hours ago, Av8ferg said: So, was able to pull my sending unit out on my 77 from the rear hatch. Before this discussion i thought they all we like this. I bought a new o-ring and locking ring when I put in it back in. I’ve read somewhere to be careful pulling off the wires from the unit as they can fracture at the connection easily. I didnt have a problem. I know they changed the deck lid configuration in the middle of 77. I have the deck lid that curves upward towards the taillight versus the standard flat deck (wish I had the flat decking) . Did you take any pics of that? Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-562195 Share on other sites More sharing options...
MM569457 Posted November 22, 2018 Author Share #44 Posted November 22, 2018 I’ll keep these comments in mind when I reinstall the sending unit. Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-562202 Share on other sites More sharing options...
MM569457 Posted April 28, 2019 Author Share #45 Posted April 28, 2019 Ok I’ve been gone for a few months. Spring time means time to start working on the Z again. good progress, I had the R200 rear end installed. Gas tank has been dropped off for cleaning. Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-574402 Share on other sites More sharing options...
siteunseen Posted April 28, 2019 Share #46 Posted April 28, 2019 On 11/22/2018 at 10:16 AM, dmorales-bello said: Did you take any pics of that? Old I know but here's a pic thanks to Hoover, @240260280 1 Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-574407 Share on other sites More sharing options...
Captain Obvious Posted April 29, 2019 Share #47 Posted April 29, 2019 On 11/21/2018 at 10:33 PM, Av8ferg said: So, was able to pull my sending unit out on my 77 from the rear hatch. I bought a new o-ring and locking ring when I put in it back in. @Av8ferg, Where did you get the O-ring and lock ring for the fuel sender? I'd like to pull mine out and figure out why it's not accurate, but I would like have an O-ring and lock ring on hand before I take it apart. I'm assuming if I have new ones here, I'll be able to re-use the old ones. 1 Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-574450 Share on other sites More sharing options...
grannyknot Posted April 29, 2019 Share #48 Posted April 29, 2019 (edited) https://screenshots.firefox.com/oJnQuUfl3VytE0U0/www.thezstore.com Edited April 29, 2019 by grannyknot Link to comment https://www.classiczcars.com/topic/60341-resurrecting-a-1977-280z/?page=4#findComment-574451 Share on other sites More sharing options...
