Wired the aftermarket fuel pump. I had to adjust the crimp connector to take the wire from the positive connector. I used electrical tape to insulate…. I will probably use a better method later.
Edited by MM569457
I went with Mr Gasket. I bought it in 2018 when they weren’t available (oem) and installed it. I’ll give it a try. It’s 4.5 psi so it should work with the carbureted engine that’s going in.
Edited by MM569457
5 minutes ago, siteunseen said:
The title threw me too.
Here's a good thread if you haven't already seen it.
Much appreciated! I’m getting close to dropping the engine. Going to remove all the emissions parts and clean out the engine bay.
  • 3 weeks later...
Replaced the drivers seat, or at least tried to.
did try to bleed the brakes today. I am getting no break fluid to the rear drums and while pressing the brake pedal I hear a loud “whooshing” sound from the engine bay.
im guessing there is a leak somewhere? If so how would I troubleshoot?
Just did my seats… there is a good video based on a forum member post.
  • Who's Online   2 Members, 0 Anonymous, 1,421 Guests (See full list)
